Play mode without welding
  • Hello folks.
    I have a question, I made some programs with the arcon instruction inside, and I'd like to know if it's possible to use them in play mode but without the welding part.
    I know it sounds useless, but the Marketing service from my company wants to make videos of my work without the welding at real speed.
    Thanks in advance!
    EDIT : I'm using a MA1900 with a DX100 I don't know if that helps.
  • To run the job in Play at programmed speed without welding:
    In Play mode, looking at the job, go to UTILITY in the menu area. In the drop-down SETUP SPECIAL RUN. Go to CHECK-RUN and press SELECT to change to VALID.
