Change Axis Master Value
  • wag_FFU
  • February 3, 2021 at 12:56 PM
  • wag_FFU
    86
    I´m Working with a Fanuc P-250iB/15. controllore R30iB
    Our Tool is mounted with the face at 30 degrees on the Axis numer 6, Is not a problem (Is not a problem at all)
    but for our client is simply unaccettable. The Great Idea than come from this guys is to Master the Robot Axis 6 at-30 degree, so The tool will face 0 Degree.
    Now the Question, I can master the robot at -30 deg, but Every time i restar the robot , the master pos Value in "single Axis Master" come back to Standard Value (0 deg for axis 6)
    Is there a way, to configure the master pos for one axis different than the standard? tnx
  • Fabian Munoz
    133
    Articles
    1,517
    • February 3, 2021 at 1:01 PM
    Hi
    What about making an adopter plate to rotate the tool 30 degrees ?
    Retired but still helping
  • wag_FFU
    86
    • February 3, 2021 at 1:31 PM
    Quote from Fabian Munoz
    Hi
    It´s too late, But the tool (in robot) was right! the problem is only because for the operator is too complicate to understand than he must use a tool number and not the tool zero...
  • pdl
    270
    1,533
    • February 3, 2021 at 3:16 PM
    What you are describing should work, I've done it before myself. Are you remembering to calibrate after doing the single axis master?
  • wag_FFU
    86
    • February 3, 2021 at 3:43 PM
    Quote from pdl
    Yes I did, It Works Fine, The only problem is with the "single Axis Master" menu.
    When the axis number 6 is at "zero", should be calibrate with -30 deg. but the "master pos" is set to zero (normal Pos) That means than the Operator Whom can´t handle to move the robot usig tool number, should insert -30 deg every time the robot should be calibrated .
    My question is, There is a way to change the Master Pos in robot , to Show -30 deg default when the menu "single Axis Master" is openend?
  • Erik Olsen
    54
    5
    177
    • February 3, 2021 at 4:31 PM
    Why would operators be opening the mastering menu?
    You can change the "(MSTR POS )" values from these system variables:
    $PARAM_GROUP[x].$MASTER_POS[x]
    Power cycle for the change to take effect. I have not tried this on any actual robots, so I have no idea if this value is only used by the mastering menu or if it has a function somewhere else. Take backups and try at your own risk.
    Edited once, last by Erik Olsen (February 3, 2021 at 4:47 PM).
  • hermann
    407
    2,612
    • February 4, 2021 at 9:19 AM
    Quote from wag_FFU
    .. than he must use a tool number and not the tool zero...
    Tool zero doesn't make sense at all. Or is the tcp in the center of the flange? Can't imagine a tool like that. Jm2c.
  • AutoMattic21
    47
    • April 20, 2021 at 1:32 PM
    Quote from wag_FFU
    Did you ever figure out why those value reset to 0?
    We're having the same issue now, trying to master a 4 robot cell now and we go through and do the single axis mastering for all the joints, only to reset the robots and all the values we entered are gone/back to zero.
  • wag_FFU
    86
    • April 20, 2021 at 5:14 PM
    Sorry but are you trying to execute the "Single axis master" for 4 Paint robots? Or are simple Hanfling robots? The single axis master robot are Machine parameter than are used to calibrate the robot according to the axis signs. Why should you set it to zero?
  • AutoMattic21
    47
    • April 20, 2021 at 5:42 PM
    Quote from wag_FFU
    disregard, we misunderstood what was going on with our system. turned out we didnt have an issue afterall
Similar Threads
  • BZAL error
    • eorka333
    • March 30, 2017 at 10:31 PM
    • Fanuc Robot Forum
  • Mastering at a Non-zero position - R30iA Controller Fanuc
    • alive15
    • July 1, 2020 at 4:12 PM
    • Fanuc Robot Forum
  • Lost home position
    • Morthe1st
    • March 4, 2020 at 1:00 PM
    • Fanuc Robot Forum
  • IRVision and Master Alignment
    • pcather
    • October 12, 2018 at 8:50 AM
    • Fanuc Robot Forum
  • Having two switch between 2 masters
    • bigemike
    • October 1, 2018 at 3:20 PM
    • Fanuc Robot Forum
  • World Coordinates Error cannot move linear.
    • AML1994
    • July 29, 2018 at 12:50 PM
    • Fanuc Robot Forum
  • World Coordinates error
    • AML1994
    • July 18, 2018 at 8:46 PM
    • Fanuc Robot Forum
  • Lost mastering... Robot at a known position. Can I remaster to this posn?
    • factoryrat
    • October 26, 2017 at 5:09 PM
    • Fanuc Robot Forum
  • Fanuc Controller 30iB kinematic model angles
    • cvancleef
    • August 4, 2017 at 6:33 PM
    • Fanuc Robot Forum
