7th Axis Degree manipulation
  • SU05LLY
  • February 2, 2021 at 6:51 PM
  • SU05LLY
    30
    Evening Forum,
    Tech Specs:
    KR3 - R540
    KSS 8.6.6
    External Axis : MG-8_KSPsr12 ( #ENDLESS ROTATION )
    Transmission Ratio : 10 / 1
    Query:
    LIN movement between two points, we alter / want to alter the ".E1" of the ROTARY external axis. For example:
    xApproachPosition.E1 = 0.0
    XTargetPosition.E1 = rGlobalDeclaredVariable
    PTP ApproachPosition
    LIN TargetPosition
    However, should I modify the XTargetPosition.E1 ( before the program is called ) to a value it doesn't achieve this by the time the displacment is achieved.
    NOTE: The rotations could be many MANY revolutions,
    In short, I'm wanting the robot LIN displacement to be controlled so that the .E1 rotation is completed @ the same time. ( the set up to me should be deployed as synchronous? )
    Many thanks
  • Fubini
    282
    1,898
    • February 2, 2021 at 7:16 PM
    Sorry, I do Not get your question. In any movement command all axes start and end simultaneously unless an axis is set to asynchronous. But in the latter case they would be programmed using asy_ptp not lin.
    Fubini
  • SU05LLY
    30
    • February 3, 2021 at 8:15 AM
    Good morning Fubini
    Appologies, I was doubting myself even as I was writing the above and could / should of made it more clear....
    Essentially, I'm driving a probe vertically up an engine valve stem, and whilst moving up this valve stem, I'm needing to rotate the turntable ( 7th axis ) that it is mounted onto a set number of degrees of rotation.
    to make certain we probe all the surface, this rotation is not fully calculated just yet, so it is abit of trial and improve.....
    Many thanks
Similar Threads
  • Frame Transforms
    • atomic_robo
    • June 28, 2018 at 6:55 PM
    • KUKA Robot Forum
