I have posted about this before and received ideas but I am still having issues. So, I have a main program doing the work, but I am looking to add a return to home program which is separate from the main program. I am using a button on HMI to call this program after the main is faulted for some reason. can someone go through the steps needed to abort the main program an the call the return to home program. I am obviously not doing something correct!! After the robot is home I want the main to be called back. I am using the robot in remote with plc inputs/outputs. Thanks again.
home program
Jerryl859 -
February 1, 2021 at 5:04 PM -
There is more than 1 way to do this
Set MASTER as your main program is you abort/start
There are a lot of post describing how to do this, (Configuration setup, etc, etc)
MASTER Program
2 lbl 1
3 if uo7= off jump lbl 98
5 LBL 2
6Your program starts here
7
51
52 Your program ends here
53 jmp lbl 2
54
55 lbl 98
56 call revovery This program will send the robot home magically
57 jmp lbl 1
So in this scenario, if the program is faulted it will automatically return to the top of the program correct??? That is dependent upon on a variable correct????
When faulted, somebody has to abort it and then , yes, will go back to top of MASTER program
You set this up doing MENU , SETUP , Prog Select ..............
and also some set up in the configuration (first ten lines )
We (the forum) had a long post about this
You dont have to change any variables on the variables table
Ok thank you, sorry for the trouble
