... bom dia pessoal... Gostaria de uma ajuda de vocês referente a comunicação de ethernet ip de um krc2 Gostaria de comunicar para tocar variaveus com o krc2, porem.não consigo a comunicação ja tentei com 2 eds genericos mais ainda não consegui êxito...
Comunicação ethernet/ip
ayrtim -
January 28, 2021 at 3:04 PM -
panic mode
January 28, 2021 at 3:22 PM Moved the thread from forum KUKA Robot Forum to forum Português (Portuguese). -
you need to post more details including role of each node, version etc.
usually PLC is setup as MASTER and KRC is SLAVE
this means in Omron PLC software you need to add slave to EIP network and parametrize it.
you will need generic EDS for this but will need to edit it yourself.
