I tried to write on KukaForum but no one answered me. Who did connection kuka and kemppi with help devicenet, can u pls send me message. I have problem with connection. I use EK1100 and EL6752. I have checked a lot already, the project too (there are questions about the ArcPulseEN settings whether they affect the connection or only on weld setings. I am using the default values.) . But still there is an error that station 3 (welding machine) is not activated. But I have 24V on EK1100 and this module fine. Tell me what I can do?
Kuka KR 6-2 + Kemppi 450 Pulse
NickBabin -
January 28, 2021 at 5:11 AM -
Hmmmm no one want to help me??? Or i do something wrong??
it appears that nobody is willing to engage in guesswork.
your posts is just too ambiguous. to get help you need to provide some specifics to help form an opinion
but so far you are successfully avoiding any details.
DeviceNet is a simple network discussed ad-nauseum. and if you don't wish to share details of your setup, you will need to rely on yourself...
example mistakes:
QuoteI tried to write on KukaForum but no one answered me.
link would be helpful, are we supposed to do all digging for you?
QuoteWho did connection kuka and kemppi with help devicenet, can u pls send me message.
what the heck is this... "kemppi"? posts exact model, EDS, picture, devicenet port pinout, wiring, configuration and anything else that can be useful. are you sure your "kempi" is a DeviceNet slave? i have seem welders that can only be configured as master and to make them work, KRC would need to act as slave (master to master communication does now work)
QuoteI have problem with connection.
then post connection details. how are we supposed to know what you have there?
QuoteI use EK1100 and EL6752.
how exactly? is that the only module? how is it wired/powered?
QuoteI have checked a lot already,
we don't know what is it that you have already checked. but if you checked the right thing, you would have found the solution.
Quotethe project too (there are questions about the ArcPulseEN settings whether they affect the connection or only on weld setings. I am using the default values.) .
you sure seem to like to let people guess.... how about exact versions of your software (KSS, tech options)
QuoteBut still there is an error that station 3 (welding machine) is not activated.
i don't follow this reasoning. how are those two sentences related? you get message that one node is not working but you go and measure voltage on a different node? and then you don't even tell WHERE on that node you measured voltages? EK1100 needs 24VDC supply at two places. EL6672 and all DeviceNet slaves need 24VDC too. and termination etc.
QuoteTell me what I can do?
if you need help, post enough detail that makes meaningful answer possible.
Взаимодействие с другими людьми
example mistakes:
Ok, thx. I will formulate the idea correctly!
