I puchased 3 Kawasaky robots, two FS20N and one FS30L, built in 2001 with approximativel 13000 hours of service each.
I would like to do crafts with one of them at least versus use a 3 axis cnc machine...
The probems are, because they are few, described below and i'm for sure looking for some help if you don't mind:
So the probems are:
- First i'm a quite noob in this domain and in the learning curve
- The only i have is the robots and electric cabinets (the seller cut all copper cables (axes, power, pendant, floppy disk...) to resell it independantly... what a pity isn't it ?)
I came to an official Kawasaki reseller to see the invoice to put one back to life. I'm also considering the possibility to use another electric and modern command box, with ethernet as well.
Pehaps some of you would like to help in this domain ?
thanks in advance
