Hi all,
I have a query on interrupts when running tests in T1. I have a program that jumps to a sub routine---executes some code----then if an interrupt signal is high should jump to an interrupt routine.
While testing in T1, the main routine is running, then the sub routine starts to run but the interrupt sequence does not appear to be called even though the signal (input) to call the interrupt goes high.
I'm not sure if it is something that will not work in T1 mode or whether there is a problem in my interrupt code. I have included extracts from code below. Thanks
SubRoutine ()
;FOLD BASISTECH INI
GLOBAL INTERRUPT DECL 3 WHEN $STOPMESS==TRUE DO IR_STOPM ( )
INTERRUPT ON 3
GLOBAL INTERRUPT DECL 10 WHEN $IN[14]==TRUE DO SLIPSHEET_Find ( )
INTERRUPT ON 10
BAS (#INITMOV,0 )
;ENDFOLD (BASISTECH INI)
Interrupt Routine()
&ACCESS RVP
&REL 9
&PARAM EDITMASK = *
&PARAM TEMPLATE = C:\KRC\Roboter\Template\vorgabe
&PARAM DISKPATH = KRC:\R1\Program
DEF SLIPSHEET_Find( )
;FOLD INI;%{PE}
;FOLD BASISTECH INI
INTERRUPT ON 3
BAS (#INITMOV,0 )
;FOLD USER INI
;Make your modifications here
;ENDFOLD (USER INI)
;ENDFOLD (INI)
BRAKE
XTEMP_POS2=$POS_ACT
XTEMP_POS2.Z=XTEMP_POS2.Z+50
;FOLD SPTP TEMP_POS2 Vel=40 % PDAT7 Tool[1]:kitting_Head Base[0] ;%{PE}
;FOLD Parameters ;%{h}
;Params IlfProvider=kukaroboter.basistech.inlineforms.movement.spline; Kuka.IsGlobalPoint=False; Kuka.PointName=XTEMP_POS2; Kuka.BlendingEnabled=False; Kuka.MoveDataPtpName=PDAT7; Kuka.VelocityPtp=40; Kuka.VelocityFieldEnabled=True; Kuka.ColDetectFieldEnabled=True; Kuka.CurrentCDSetIndex=0; Kuka.MovementParameterFieldEnabled=True; IlfCommand=SPTP
;ENDFOLD
SPTP XTEMP_POS2 WITH $VEL_AXIS[1] = SVEL_JOINT(40.0), $TOOL = STOOL2(FTEMP_POS2), $BASE = SBASE(FTEMP_POS2.BASE_NO), $IPO_MODE = SIPO_MODE(FTEMP_POS2.IPO_FRAME), $LOAD = SLOAD(FTEMP_POS2.TOOL_NO), $ACC_AXIS[1] = SACC_JOINT(PPDAT7), $APO = SAPO_PTP(PPDAT7), $GEAR_JERK[1] = SGEAR_JERK(PPDAT7), $COLLMON_TOL_PRO[1] = USE_CM_PRO_VALUES(0)
;ENDFOLD
XTEMP_POS2=$POS_ACT
XTEMP_POS2.Z=XTEMP_POS2.Z-50
;FOLD SPTP TEMP_POS2 Vel=40 % PDAT8 Tool[1]:kitting_Head Base[0] ;%{PE}
;Params IlfProvider=kukaroboter.basistech.inlineforms.movement.spline; Kuka.IsGlobalPoint=False; Kuka.PointName=XTEMP_POS2; Kuka.BlendingEnabled=False; Kuka.MoveDataPtpName=PDAT8; Kuka.VelocityPtp=40; Kuka.VelocityFieldEnabled=True; Kuka.ColDetectFieldEnabled=True; Kuka.CurrentCDSetIndex=0; Kuka.MovementParameterFieldEnabled=True; IlfCommand=SPTP
;ENDFOLD
;ENDFOLD
;ADJUST POSITION MOVE HEAD DOWN TO SLIPSHEET PICK POSITION
XTEMP_POS2=$POS_ACT
XTEMP_POS2.Z=$POS_ACT.Z-100
;FOLD SLIN TEMP_POS2 Vel=0.2 m/s CPDAT3 Tool[1]:kitting_Head Base[0] ;%{PE}
;Params IlfProvider=kukaroboter.basistech.inlineforms.movement.spline; Kuka.IsGlobalPoint=False; Kuka.PointName=XXTEMP_POS2; Kuka.BlendingEnabled=False; Kuka.MoveDataName=CPDAT3; Kuka.VelocityPath=0.2; Kuka.VelocityFieldEnabled=True; Kuka.ColDetectFieldEnabled=True; Kuka.CurrentCDSetIndex=0; Kuka.MovementParameterFieldEnabled=True; IlfCommand=SLIN
;ENDFOLD
SLIN XTEMP_POS2 WITH $VEL = SVEL_CP(0.2, , LCPDAT3), $TOOL = STOOL2(FTEMP_POS2), $BASE = SBASE(FTEMP_POS2.BASE_NO), $IPO_MODE = SIPO_MODE(FTEMP_POS2.IPO_FRAME), $LOAD = SLOAD(FTEMP_POS2.TOOL_NO), $ACC = SACC_CP(LCPDAT3), $ORI_TYPE = SORI_TYP(LCPDAT3), $APO = SAPO(LCPDAT3), $JERK = SJERK(LCPDAT3), $COLLMON_TOL_PRO[1] = USE_CM_PRO_VALUES(0)
;ENDFOLD
;TURN ON VAC PODS FOR PICKING OF SLIPSHEET
;FOLD OUT 7 '' State= TRUE;%{PE}%R 8.3.22,%MKUKATPBASIS,%COUT,%VOUTX,%P 2:7, 3:, 5:TRUE, 6:
$OUT[7]=TRUE
;ENDFOLD
;FOLD OUT 8 '' State= TRUE;%{PE}%R 8.3.22,%MKUKATPBASIS,%COUT,%VOUTX,%P 2:8, 3:, 5:TRUE, 6:
$OUT[8]=TRUE
;ENDFOLD
;FOLD OUT 15 '' State= TRUE;%{PE}%R 8.3.22,%MKUKATPBASIS,%COUT,%VOUTX,%P 2:15, 3:, 5:TRUE, 6:
$OUT[15]=TRUE
;ENDFOLD
;FOLD OUT 16 '' State= TRUE;%{PE}%R 8.3.22,%MKUKATPBASIS,%COUT,%VOUTX,%P 2:16, 3:, 5:TRUE, 6:
$OUT[16]=TRUE
;ENDFOLD
;FOLD WAIT Time=2 sec;%{PE}%R 8.5.19,%MKUKATPBASIS,%CWAIT,%VWAIT,%P 3:2
WAIT SEC 2
;ENDFOLD ; WAIT FOR VACUUM GRIP
;ADJUST POSITION TO LIFT SLIPSHEET 20MM IN ORDER TO REDUCE VACCUM BETWEEN SHEETS
XTEMP_POS2=$POS_ACT
XTEMP_POS2.Z=$POS_ACT.Z+20
;FOLD SLIN TEMP_POS2 Vel=0.2 m/s CPDAT4 Tool[1]:kitting_Head Base[0] ;%{PE}
;Params IlfProvider=kukaroboter.basistech.inlineforms.movement.spline; Kuka.IsGlobalPoint=False; Kuka.PointName=XTEMP_POS2; Kuka.BlendingEnabled=False; Kuka.MoveDataName=CPDAT4; Kuka.VelocityPath=0.2; Kuka.VelocityFieldEnabled=True; Kuka.ColDetectFieldEnabled=True; Kuka.CurrentCDSetIndex=0; Kuka.MovementParameterFieldEnabled=True; IlfCommand=SLIN
;ENDFOLD
SLIN XTEMP_POS2 WITH $VEL = SVEL_CP(0.2, , LCPDAT4), $TOOL = STOOL2(FTEMP_POS2), $BASE = SBASE(FTEMP_POS2.BASE_NO), $IPO_MODE = SIPO_MODE(FTEMP_POS2.IPO_FRAME), $LOAD = SLOAD(FTEMP_POS2.TOOL_NO), $ACC = SACC_CP(LCPDAT4), $ORI_TYPE = SORI_TYP(LCPDAT4), $APO = SAPO(LCPDAT4), $JERK = SJERK(LCPDAT4), $COLLMON_TOL_PRO[1] = USE_CM_PRO_VALUES(0)
;ENDFOLD
;DELAY TIME FOR VACUUM BETWEEN PICKED SHEET AND STACK TO DISSIPATE
;FOLD WAIT Time=1.5 sec;%{PE}%R 8.5.19,%MKUKATPBASIS,%CWAIT,%VWAIT,%P 3:1.5
WAIT SEC 1.5
;ENDFOLD
RESUME ; RETURN TO SLIPSHEET_Pick PROGRAM
END
