I have a question now. The start value of this analog quantity has always been 1600. After I manually change it, press the reset key and it will become 1600 again. I looked at the background program and found that nothing was written in it. Then I found the cold start automatic running program and found that the pashell program was added in it, but I didn't find it. There was nothing in the hot start. How can I change the start value
Analog output start value
- ecopaint
This is system configuration screen ,thank you very much
Something must be setting it. Can you tell us what model controller and software version. Also provide an 'all of the above' backup.
ok,version V8.20P/31 PaintTool,the backup file is too large, about 65M, and the attachment can only be uploaded to 8M
That's an image backup which is not what I would want. Im asking for the file backup. Should be much smaller but still can't be an attachment, you need to use something like Dropbox.
dear sir
I tried to delete the cold start auto-run program, and then found that the start value of AO became 0, but I did not find the program PASHELL in all the programs of theTP, Luckily I saw the program PASHELL in the program backup. it is a VR file, how can I modify it?
the attachment is the program backup, the link is the mirror file.
Thanks sir
VR is a variable file not a program. I have never seen anyone use that as an Auto-execute program before. I would look over the karel variables in your program to see if anything sheds light there.
thanks you sir
Do you have a Karel program called PASHELL? Did you delete PASHELL.PC? When you delete a karel program, the .VR of the same name will still remain in memory. On older robots, there was no way to make karel .pc backup. This should be enabled by version 8.2, but maybe it was disabled by a system variable, also maybe this is paint tool specific. I've never used paint tool so I can't be of too much help there.
I only deleted the name of the cold start autorun program. I didn't find PASHELL.PC in all the programs , The PCSHALL.VR I found it in the backup file,
What is the IO assign to? maybe try changing to another port to eliminate background settings.
It could be new value assigned from background task, PLC or BG logic. Check the Meun->Status->Program
or check the /MD/PRGSTATE.DG -
IO分配给什么?也许尝试更改为另一个端口以消除后台设置。
它可以是从后台任务,PLC或BG逻辑分配的新值。检查菜单->状态->程序
或检查/MD/PRGSTATE.DGMaybe I can try to change the AO configuration,
