External axis calibration setup error
  • crk
  • January 23, 2021 at 7:03 PM
  • crk
    76
    Hello everyone,
    I'm trying to calibrate the DKP400 turn-tilt table external axis as external kinematics of my KR30 HA robot,
    as the operating manual says, it should be simple,
    touching a point (in my case X 210mm far from the DKP400 flange center) four times in different approaches.
    So the point $ET1_TPINFL is declared, as external axes manual says, like this in machine.dat :
    FRAME $ET1_TA1KR={X 0.0,Y 0.0,Z 510.0,A 0.0,B 0.0,C 90.0}
    FRAME $ET1_TA2A1={X 0.0,Y 340.0,Z 0.0,A 0.0,B 0.0,C -90.0}
    FRAME $ET1_TA3A2={X 0.0,Y 0.0,Z 0.0,A 0.0,B 0.0,C 0.0}
    FRAME $ET1_TFLA3={X 0.0,Y 0.0,Z 0.0,A 0.0,B 0.0,C 0.0}
    FRAME $ET1_TPINFL={X 210.0,Y 0.0,Z 0.0,A 0.0,B 0.0,C 0.0}
    But when i select
    Setup > Measure > External kinematics > Root point,
    after choosing system no 1, giving it a name, and choosing continue,
    the KSS 5.6.8 (running on KRC2) gives this error :
    "It is not possible to measure the external kinematic 1 of type #NONE"
    Has anyone faced the same issue? Is there a way to proceed with the calibration?
    The Tool is selected and Base is too (0, 0, 0, 0, 0, 0,)
    Thank you
  • DannyDJ
    67
    505
    • January 23, 2021 at 7:46 PM
    Hello, check this parameter in machine.dat
    DECL EX_KIN $EX_KIN={ET1 #EASYS,...
    do you have there #NONE?
    and also check this DECL ET_AX $ET1_AX={TR_A1 #E1,TR_A2 #E2,TR_A3 #NONE}
  • crk
    76
    • January 24, 2021 at 3:58 PM
    Yes, that solved! I was missing this part. Thank you
Similar Threads
  • Mastering homemade external axis with a KR150 KUKA motor
    • jschmidt
    • May 8, 2018 at 4:50 PM
    • KUKA Robot Forum
  • Collaborative
    • droth
    • August 23, 2017 at 6:41 PM
    • Fanuc Robot Forum
  • calibrate
  • kinematics
