KUKA AGILUS BATTERY AND SMARTPADs KEYSWITCH
  • Gabigol
  • January 22, 2021 at 12:43 PM
  • Gabigol
    34
    Hello guys, how are you?
    I have two quick questions:
    1- The original battery on KRC4 Compact is 12V 2,6Ah. What happens if I use a 12V 2,3Ah battery instead? Does one of you guys use a lower current battery on this controllers? There will be the "Old battery detected" warning?
    2- The switchkey (to T1, T2, AUT, EXT key) on the SmartPad version one (with orange details), works on the Smartpad version two? (The version that comes with newest KRC4 Smallsizes, has black details and hand supports on the sides).
    Thank you!
  • panic mode
    1,267
    13,033
    • January 22, 2021 at 6:36 PM
    what happens if you replace car fuel tank to one that is half size?
  • Gabigol
    34
    • January 22, 2021 at 6:53 PM
    Okay, the car will run less. You mean the battery will die sooner? What about the "Old battery detected" warning? Will it appear?
    About the second question, I believe it's a simples question, I just don't have both smartpads here to test it out. Could you please answer me? Thanks.
  • panic mode
    1,267
    13,033
    • January 22, 2021 at 7:33 PM
    maybe... i don't have an answers to 'what will happen' type of questions and i am not claiming to be able to predict what will or will not be when unknown product is connected to something controlled by something propriatery. so my guess is good as yours. if you want to find out, try it yourself. i also don't see why would someone spend $$$ on something and then try to pick sub-pair substitute that does not meet manufacturer specification.
    also i don't have access to any robot (working remotely) so maybe someone else may chime in.
  • the leg
    643
    • January 24, 2021 at 3:45 PM
    Both smart pads are interchangeable i believe .
    I have used a smart pad 1 on system with kss V8.6.6 and had no issues with it
  • panic mode
    1,267
    13,033
    • January 25, 2021 at 1:27 AM
    yes the smartPads are interchangeable... not sure if they keys are
  • AGILUS
