first time i'm using Profinet with CP1604 card with R30iB+.
I don't have any led lit or flashing when I plug the Ethernet cable with my PC.
What is the first steps to make it work?
The manual is not clear enough for me.
Thanks.
Thanks.
Turn off power and pull the card and make sure Fanuc actually assembled it. I had that problem and they didn't bother screwing the CP1604 daughterboard to the main board. It fell off when I pulled it out.
Another time I had a dead board, and had to RMA it to Fanuc.
The card seems ok.
I aslo tried another one just in case.
It's like if the controller does'nt see the card.
Just to be sure, the 24V connector is only for external power supply?
Thanks.
Yeah, the connector is there for if you want to keep the network online if the robot is powered off. Otherwise the card gets its power internally.
Another question would be if you have the profinet option installed on the
Yes, option installed.
When I try to Update FW I have PRIO-600 PNIO board not installed error and have a timeout after the 7 minutes waiting.
I found that PSU Card is the problem.
The CP1604 card do not have power.
I swaped the PSU card with another one and it works.
Thanks.
