KUKA Cross-section of foundation, Machine frame mouting Drawing
  • SavageInT1
  • January 21, 2021 at 10:14 AM
  • SavageInT1
    13
    Hello, guys
    I was wondering if someone has the DWG of that picture that I took from the Kuka Docs.
    I tried to recreate it in Autocad, but it's not the same...I also tried to convert it in many ways but without any luck.
    Any idea where I can find that as a DWG file.
    Cheers,
  • panic mode
    1,278
    13,079
    • January 21, 2021 at 3:12 PM
    well you could ask KUKA but good luck with that.
    also you don't mention which manual that is. people that cannot properly state the problem when asking for help, tend to get poor or no help at all.
    don't have AutoCad on this machine but i don't see why it would take more than 10min to recreate the drawing as is. only few dimensions are shown so the simplest way to get this recreated is to:
    1. paste image into DWG
    2. use different color lines (red or blue for example) and just cover boundaries of key regions
    3. delete image so only lines remain,
    4. then use hatch to fill shaded areas with suitable patterns
    5. format line thickness to look more like image
    6. select all lines to change color as needed and scale drawing
  • SavageInT1
    13
    • January 22, 2021 at 10:37 AM
    Thanks for the answer, I did the recreation process already, I was just wondering if there was someone who has the original drawing, because as you've said asking Kuka won't be easy or I won't even get an answer, at least not soon. The documentation was about Quantec Prime K robot series specifications.
    Thanks again.
  • CAD
  • DWGs
  • Drawing
