KR C4 EtherNet/IP 1.0
  • I recently asked the kuki service about the price of KR C4 EtherNet / IP 1.0 .
    I got this information:
    Everything under one index 0000202883
    -KR C4 EtherNet / IP 1.0
    -KUKA.EtherNet IP scanner / adapter (without CIP Safety)
    KUKA.EtherNet IP scanner / adapter (without CIP Safety) is an ethernet pci card?I asked about the KR C4 EtherNet / IP 1.0 software itself .
  • EIP 1.0 is a software option for KSS8.2. Supported functionality of that software is Ethernet/IP scanner ("master") and Ethernet/IP adapter ("slave").
    terms master/slave tend to be not popular with language police. people with thin skin people and those that see racism or skin color everywhere. so the sensitive ones were sometimes called snowflakes but even that word was deemed unacceptable. to deal with them, oppressed manufacturers tried to come up with terminology that does not rub anyone the wrong way and invented alternatives like "scanner/adapter" or "controller/device" etc.
    btw. why would you suggest version to KUKA? they are supposed to propose it to you based on your system info. for example why go for old 1.0 when newer 1.1 may do (both work for KSS8.2). i would always go for newer version. there is a reason someone decided to create a newer version.
    https://xpert.kuka.com/ID/AR5311
