How to enable numbers into Program name - Fanuc
  • josephtoftjr
  • January 20, 2021 at 11:04 AM
  • josephtoftjr
    29
    Hey,
    We just got new Fanuc R-2000iC/210L Robots with R-30iB plus controller. When creating a program, it will only let me use letters when naming a program. How do I enable the use of numbers and symbols as well?
  • HawkME January 20, 2021 at 1:23 PM
    Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum.
  • HawkME
    568
    3,268
    • January 20, 2021 at 1:24 PM
    You can use letters, numbers, and underscore. But it must start with a letter.
  • bencor21
    10
    109
    • January 20, 2021 at 1:44 PM
    I've been seeing some people who like to begin all of their created program names with underscores so they all grouped together in the program screen. Not a fan but whatever.
  • retobor
    18
    207
    • January 20, 2021 at 1:47 PM
    Quote from bencor21
    Collections are a solution to that.
  • josephtoftjr
    29
    • January 20, 2021 at 4:28 PM
    I solved the problem.
    Another question, When stepping through a program in T1, the fastest I can only turn my overide up to 50%. Is there a way to speed that up?
  • Nation
    Typical Robot Error
    542
    1,924
    • January 20, 2021 at 4:41 PM
    Set $SCR.$TPENBLEOVRD to 100 and it will let you run at a 100% in teach.
    Edit: Wrong var. See my response below.
  • josephtoftjr
    29
    • January 20, 2021 at 5:57 PM
    I'm not seeing $SCR.$TPENBLEOVRD in variables. These robots are brand new. Do think that Fanuc got rid of it for safety purposes?
  • Nation
    Typical Robot Error
    542
    1,924
    • January 20, 2021 at 6:28 PM
    I can't confirm on a real robot, but it is present on v9.30 of Handlingtool.
  • josephtoftjr
    29
    • January 20, 2021 at 6:43 PM
    Found it, its actually at 10, and it won't let me change it....says write protected. Any other Ideas?
  • bencor21
    10
    109
    • January 20, 2021 at 6:58 PM
    try changing it in a controlled start
  • Nation
    Typical Robot Error
    542
    1,924
    • January 20, 2021 at 7:02 PM
    • #11
    My mistake. Should be $SCR.$RUNOVLIM.
  • pdl
    270
    1,533
    • January 20, 2021 at 7:34 PM
    • #12
    Quote from Nation
    Yup, that's definitely the one. It defaults to 50 on a new software load or straight from the factory. It's usually one of the first things I change.
    $SCR.$TPENBLEOVRD is what the override gets set to when you enable the teach pendant.
  • josephtoftjr
    29
    • January 20, 2021 at 8:26 PM
    • #13
    yes sir! I got it now! thanks guys
  • Bwille
    8
    • October 4, 2024 at 2:36 PM
    • #14
    Quote from josephtoftjr
    Were you able to get the program name to start with a number? if so how
  • Nation
    Typical Robot Error
    542
    1,924
    • October 4, 2024 at 3:23 PM
    • #15
    Quote from Bwille
    Quote from HawkME
    HawkME already stated it, but programs must start with a letter. It is a fundamental limitation in the controller. There is no way around it.
  • Fanuc 30ib
Users Viewing This Thread
  • 1 Guest
