dial mastering
  • mbalazs
  • January 19, 2021 at 2:38 PM
  • mbalazs
    25
    Hello. With dial mastering of an older krc1 equivalent robot, at what position of the dial should the axis be mastered? exactly at the turning point, or just as it begins to reverse direction? If the mastering should be done after, then how many fractions of a mm should it be? This is an old robot and with a short probe I get min 1.7 mm of a tool calibration error.
    panic mode
    1,280
    13,085
    • January 19, 2021 at 3:49 PM
    with Dial mastering you need to find as exactly as possible center of V-slot. so normal approach is to find the dip, then reduce speed and pass it again (and repeat as needed) until you are right at the center, not before, not after. 1.7mm error for tool calibration is quite large but that also depends on how well defined your pointer tips is, how far the TCP is from flange, size of the robot, how well it is maintained (belts tensioned correctly?) etc.
  • mbalazs
    25
    • January 19, 2021 at 4:11 PM
    Thank you. I've got 1.7mm at best, with a precision machined tipped rod mounted in a small spindle. Now I've switched to a larger spindle with an aprox. 500mm tip distance from the flange. This way I can't get below 6mm error. I once got 2.mm, but with little orentation change between xyz4 point measurements. The robot is a kr125/2. The weight of the spindle is around 40 kg. First I will try to get better results by making a more careful remastering, as you've mentioned. How much does belt tensioning influence accuracy? Does incorrect tensioning introduce more backlash?
    panic mode
    1,280
    13,085
    • January 19, 2021 at 5:20 PM
    too much tension will damage the wrist, usually it is the belts and eccentric shaft that pay the price. too little tension and wrist may be skipping the belt teeth and of course damaging belt. tension need to be really accurate (1% or so) and therefore cannot be done without proper equipment and training. if used, belts are usually in the wrist but some robot models also have belts in the robot arm.
Similar Threads
  • KUKA robot mastering without the EMT tool
    • kukitapro
    • November 25, 2017 at 8:55 PM
    • KUKA Robot Forum
  • How often do you master a KuKa robot
    • ktmf
    • March 3, 2020 at 11:42 AM
    • KUKA Robot Forum
  • VKRC1 mastering
    • Sakis97
    • June 20, 2020 at 10:20 AM
    • KUKA Robot Forum
  • KUKA Mastering
    • sw14928
    • June 11, 2019 at 10:49 AM
    • KUKA Robot Forum
  • Mastering homemade external axis with a KR150 KUKA motor
    • jschmidt
    • May 8, 2018 at 4:50 PM
    • KUKA Robot Forum
  • GM Kuka KRC1 - Hard Stops and Mastering questions
    • maaron
    • January 31, 2018 at 5:01 PM
    • KUKA Robot Forum
  • Accuracy
    • Martin84
    • December 18, 2017 at 9:19 AM
    • KUKA Robot Forum
  • Problem with calibrating tool
    • DameS
    • July 4, 2017 at 9:41 AM
    • KUKA Robot Forum
