Fanuc Karel and HTML
  • Greetings I need help.
    I am doing a custom Html page to control Fanuc robot I/O. I am doing this with help of Karel.
    Here are the programs. HTML program for sending data and Karel program for receiving data.
    I don't know why they won't work. Please help me. I picked KAREL 632 during configuration of my cell and Karel is unlocked in TP.
    The HTML page is saved in MC folder in My workcells.
    KAREL
    PROGRAM prvi -- svaki program mora zapoceti s "PROGRAM" nakon cega slijedi ime programa
    %NOLOCKGROUP -- grupe moraju biti otkljucane da bi program radio
    VAR -- sve varijable koje se koriste u programu moraju se definirati
    object : STRING[12]
    operate : STRING[12]
    INDEX : STRING[12]
    value : STRING[12]
    uobject : STRING[12] -- duple varijable koje ce se koristiti za prebacijavje teksta u velika slova
    uoperate: STRING[12]
    uindex : STRING[12]
    uvalue : STRING[12]
    value_i : INTEGER -- ostale varijable
    value_r : REAL
    index_i: INTEGER
    status : INTEGER
    i : INTEGER
    return_code : INTEGER
    ROUTINE toupper(p_char: INTEGER): STRING -- prebacivanje ulaza u velika slova
    BEGIN
    IF (p_char > 96) AND (p_char < 123) THEN
    p_char = p_char - 32
    ENDIF
    RETURN (CHR(p_char))
    END toupper
    BEGIN
    IF UNINIT(object) THEN object = ''; ENDIF -- provjera neinicializiranih varijabli prije korištenja
    IF UNINIT(operate) THEN operate = ''; ENDIF
    IF UNINIT(INDEX) THEN INDEX = ''; ENDIF
    IF UNINIT(value) THEN value = ''; ENDIF
    uobject = ''
    FOR i = 1 TO STR_LEN(object) DO
    uobject = uobject + toupper(ORD(object, i))
    ENDFOR
    uoperate = ''
    FOR i = 1 TO STR_LEN(operate) DO
    uoperate = uoperate + toupper(ORD(operate, i))
    ENDFOR
    uindex = ''
    FOR i = 1 TO STR_LEN(INDEX) DO
    uindex = uindex + toupper(ORD(INDEX, i))
    ENDFOR
    uvalue = ''
    FOR i = 1 TO STR_LEN(value) DO
    uvalue = uvalue + toupper(ORD(value, i))
    ENDFOR
    IF (uobject = 'DOUT') THEN
    IF (uoperate = 'SET') THEN
    CNV_STR_INT(uindex, index_i)
    IF (uvalue = 'ON') THEN
    DOUT[index_i] = ON
    ENDIF
    IF (uvalue = 'OFF') THEN
    DOUT[index_i] = OFF
    ENDIF
    ENDIF
    ENDIF
    IF (uobject = 'NUMREG') THEN
    IF (uoperate = 'SETINT') THEN
    CNV_STR_INT(uvalue, value_i)
    SET_INT_REG(index_i, value_i, status)
    ENDIF
    IF (uoperate = 'SETREAL') THEN
    CNV_STR_REAL(uvalue, value_r)
    SET_REAL_REG(index_i, value_r, status)
    ENDIF
    ENDIF
    return_code = 204 -- povratak NO RESPONSE koda - potrebno
    END prvi -- svaki program mora završiti s "END" nakon cega slijedi ime programa
    HTML PROGRAM
    <!DOCTYPE html>
    <html lang="hr-HR">
    <head>
    <meta charset=UTF-8>
    <div align="mid">
    <title>FANUC WEB WIZARD - Paletizacija</title> </div>
    </head>
    <body bgcolor="#4169E1">
    <h2>
    <font color="#FFFFFF">
    </fontcolor>Primjeri mogućeg sadržaja:
    </h2>
    <table>
    <tr>
    <h3>1. Postavljanje digitalnih izlaza:</h3>
    <td>
    <form action="C:\Users\kovad\OneDrive\Dokumenti\My Workcells\Projekt_IRM\Robot_1\MC\prvi" method="GET"> <!--link na karel program-->
    <div align="left">
    <input type="hidden" name="object" value="DOUT">
    <input type="hidden" name="operate" value="set">
    <input type="hidden" name="index" value="1"> <!--broj izlaza koji se mijenja-->
    <input type="hidden" name="value" value="ON">
    <input type="submit" value="Upali DOUT[1]">
    </div>
    </form>
    </td>
    <td>
    <div align="left">
    <input type="hidden" name="value" value="OFF">
    <input type="submit" value="Ugasi DOUT[1]">
    </div>
    </form>
    </td>
    </tr>
    </table>
    <table>
    <tr>
  • Try:
    <form action="/KAREL/prvi" method="GET">
    You have to use the paths of the robot itself, not the paths of your computer.
    Before You try it, export the .html via Roboguide to the virtual robot. Copying it to the local MC folder doesn't work.
  • Have you tested this using a "raw" browser command first? Typically, for a RoboGuide virtual robot, you should be able to point a browser directly to "http://localhost/KAREL/prvi?object=DOUT", and see that the string variable Object becomes "DOUT". Any errors in the KRL will be shown on the virtual pendant, so make sure you have it active.
    For testing this way, it would also help if you set up a return string to the browser, as shown in the Internet Options manual.
    That was the problem. I fixed it and it worked.
    Thank You!
