Krc2 and Fronius
  • paulfile
  • January 15, 2021 at 3:35 PM
  • paulfile
    64
    I notified the Fronius source with Kuka. But I have a problem. I can only work in one job (program no). I have defined more than one job on the source machine. When I start a program, Kuka is always welding on job1. I want to use job1, job2, job3 in one program. I want to switch from job1 to job2 in the program. how can I do that.
  • panic mode
    1,297
    13,141
    • January 15, 2021 at 3:46 PM
    select another job, read the manuals, verify configuration...
    if the table shows inputs to welder, those signals must be outputs to robot.
    if your fieldbus is setup correctly, IO are mapped correctly then robot can control this
    suppose Fronius inputs 33-40 (8bits) are mapped to robot outputs 121-128 (also 8 bits), you can have signal defined as
    SIGNAL FRONIUS_JOB_NUMBER $OUT[121] TO $OUT[128]
    then your program can assign job number values as needed.
    for example:
    FRONIUS_JOB_NUMBER = 3
    ; do something
    FRONIUS_JOB_NUMBER = 2
    ; do something else
    FRONIUS_JOB_NUMBER = 174
    ; do something else
Similar Threads
  • KRC2 Error on writing , driver DN2DRV
    • bishoy naguib
    • June 27, 2019 at 12:36 PM
    • KUKA Robot Forum
  • KRC2 connecting to Fronius
    • BigM
    • December 8, 2020 at 7:38 AM
    • KUKA Robot Forum
  • KRC2 - KSS heartbeat
    • RAS-Skordos GR
    • December 15, 2019 at 5:41 PM
    • KUKA Robot Forum
  • Kuka KRC2 configuration with TransPulse Synergic 4000
    • Francesco Pantoli
    • June 28, 2019 at 6:51 PM
    • KUKA Robot Forum
  • FAST HELP KUKA KRC2+LORCH ROBOMIG S5
    • Invaders
    • December 8, 2016 at 10:27 AM
    • KUKA Robot Forum
