Does the PPABN signal depend on me adding an external pressure switch or is there a device already in the robot? If I have to add a switch, can anyone suggest a particular model/device? I don't usually have any issues with this, but my latest install has been 'crashed' several times now due to the air getting shut off and forgotten about... at least until they attempt that first pick...
PPABN
droth -
January 14, 2021 at 3:53 PM -
- Go to Best Answer
You have to add your own pressure switch. You could buy one from a brand such as Numatics or Festo.
- Best Answer
I see a lot of programmable SMC units and current customer uses lots of the these so my guess is they must be inexpensive. This is a clean environment so if your installation is challenging, you may want to look at the other brands that may be more robust. SMC makes different versions besides the one in the attached pic. Numatics & Festo mentioned by HawkME have good reputations.
