- I want a image of VSS 8.1OR KSS 8.1
KSS 8.1 or vss 8.1 image
- haiyanglove
- Thread is Unresolved
contact Kuka
I'm affraid even KUKA will not provide this image.
VSS 8.1 was extremely buggy. Beside this, every time you download a modified WorkVisual Project inside the robo, older versions of that project were maintened on hdd. So if You are commissioning a robot, in the end of the day You will have dozens of unused projects inside your robot.
I just saw VSS 8.1 few times, and after that, all robots were upgraded to VSS 8.2.17
So, unless you have a very specific reason to use VSS 8.1, I will advice You to search for VSS 8.2.17, the one installed on VSS 8.1. robots.
haiyanglove
Changed the title of the thread from “VSS 8.1 image” to “KSS 8.1 or vss 8.1 image”.
