NX100 not booting, Yaskawa blue screen
  • white_raven
  • December 14, 2020 at 8:46 PM
  • white_raven
    8
    64
    I am having this same issue. Everything is new (maintenance crew replaced everything trying to resolve) and I still cannot boot past the bitmap image. I have a backup of the system software as well as the CMOS, but the controller will not boot past the blue robot bitmap image. Is there some process to load system software that I'm unaware of to get the robot to finish booting so that I can load the CMOS?
    Quote from prakashm
    HI guys,
    I have a Motoman NX 100/ EA1900N robot for the welding application. The robot was working fine until we started again after 3 days of holiday. Then the startup screen of Yaskawa motoman came then the white screen, and then again the Blue startup screen. After this, the system is not booting and the Yaskawa Motoman screen stays forever.
    During this time, JZNC-NIF status LED shows 8, SGDR-AXA01A shows 0, and in the power supply module the source, 5V, and P-ON LEDs are lit.
    CPU NCP 01 – LED 0 lit, LED 1 OFF
    We tried starting the controller in the maintenance mode, but still, it was not booting up. Can you please suggest us what could have gone wrong with this system. I tried removing NCP01 card and installed again, but no progress.
    I unplugged the LAN cable from the NCP01 board and switched on the controller, the same startup screen of Yaskawa Motoman comes and stays forever and not booting. Is this normal? Is there any way to find out if it’s a problem of pendant/ cable or the NCP01 Board or the NCP01 CF card?
    Thanks in advance.
  • Robodoc
    56
    7
    1,062
    • December 19, 2020 at 2:55 PM
    Hold the MAIN MENU key down and turn on the power to see if the robot will boot in Maintenance mode. If it does, your CF card is corrupt. If it does not you will have to call for service.
    Robodoc
