Hello every one. I'm new to this community and I am hoping you could help me with my problem in accessing the system variable. I am trying to change the value of $MASTER/CAL to 1 but I am getting the error message that "Edit Operation is not allowed" in system variable. Will loading passunlocker solve this? Thanks in advance.
Master/Cal
Mj03 -
December 29, 2020 at 3:28 PM -
I don't see how passwords would be involved. What are you trying to accomplish?
I'm pretty sure $MASTER/CAL is not an actual variable. Do you mean $MASTER_ENB?
What version of software is this?
I believe the variable [$UI_CONFIG.$READONLY] is what enables and disables editing. If it is true, then you have read only privilege's so when trying to edit it will give you the "Edit Operation Not Allowed" alarm. I'm not sure if you can modify the value if it is in "read only" or not, or if it will just go back to being true. I would look in your background logic to see if this variable is being set by an external device. We utilize this variable in background logic for badge readers, to prevent unauthorized employees from modifying programs. Check that variable if you want to enable editing.
