Motoman XRC Alarm 4105 [222]
  • hublew31
  • December 17, 2020 at 11:21 AM
  • hublew31
    Hello everyone!
    Lately I've been having this problem while saving and loading different jobs, by using SAVEJ and LOADJ. The robot takes forever to load the job and when a minute or two have passed "Alarm 4105 [222]" pops up. I have already tried replacing the communication cable between the PC and robot with a new one, unfortunately nothing has changed.
    Have you delt with this problem before?
    Thank you for your help and time.
  • Robodoc
    56
    7
    1,062
    • December 19, 2020 at 3:07 PM
    Are you in remote mode?
    Is the software running on the PC?
    Is the cable plugged in?
    Robodoc
  • hublew31
    • December 20, 2020 at 8:37 PM
    Yes to all of them.
  • 95devils
    235
    8
    1,951
    • December 21, 2020 at 2:05 PM
    Going to throw this out there. You have two separate threads on two generations of controllers using Visual DCI. Different problems but a common software option. Did your IT department change something on the pc's?
  • Robodoc
    56
    7
    1,062
    • December 24, 2020 at 1:42 PM
    1) Turn off the PC, reboot the robot, make sure the robot is in remote mode, power on the PC and start the software.
    2) There are RS parameters that need to be set for VDE or DCI. If you know what these parameters are, boot the robot in maintenance mode, under file, initialize the RS parameters and reboot the robot normal then set the RS parameters for VDE or DCI.
    Robodoc
Similar Threads
  • Motoman NX100 Wrong ex of SAVE inst
    • hublew31
    • December 8, 2020 at 8:14 AM
    • Yaskawa Motoman Robot Forum
  • XRC
  • Alarm
  • alarm4105
