Robot actual override procent
  • Which controller? IRC5? S4? Do you mean the speed override from the pendant? If you do, I made this code a few years ago to send the value to the PLC so the operators can't slow the robots down without us knowing about it. You'd need to map a group output to the PLC if using this specific functionality. The proc is called from Main so it checks every cycle:
    ! Declarations
    LOCAL VAR num flexpendspeed;
    LOCAL VAR num flexactual;
    ! Procedures
    PROC speed_check()
    ! Capture speed selected by flexpendant user
    flexpendspeed:=CSpeedOverride();
    IF flexpendspeed=100 THEN
    ! Sets group output value to 100 if speed is 100%
    SetGO go_SpeedValue,100;
    ELSEIF flexpendspeed<100 THEN
    ! Remove any decimals from speed value
    flexactual:=Round(flexpendspeed\Dec:=0);
    ! Set group output of actual speed to PLC
    SetGO go_SpeedValue,(flexactual);
    ! Write speed information to flexpendant screen
    TPErase;
    TPWrite " Robot system speed is not 100%";
    TPWRITE " Robot rendszer sebességét nem 100%";
    ENDIF
    ENDPROC
    You need to tell us the controller type etc. when you ask this kind of question!
  • Thanks,
    That was exactly what I was looking for!
