  3. Cobot Help and Discussion Center
  4. KUKA LBR IIWA
Background Task TCP/IP will not reconnect after synchronization
  • JM212
  • December 9, 2020 at 2:19 AM
  • JM212
    43
    I have written up a TCP/IP Background Task. The robot is acting as the server and I am trying to constantly listen to incoming clients. I am currently getting an error every time I synchronise the robot with the Kuka Sunrise Workbench. The error seems to be that when I reconnect I am unable to as the Socket is already Bound. This obviously means I am not closing the socket. But I am not too sure how to close the socket on an abrupt termination of the TCP/IP background task, especially when I hit the task to stop or when I go to synchronise.
    Is there a way that I could attempt to close the socket before the background task is shutoff? OTherwise I have to power cycle after everytime I synchronise.
    Java
    package application;
    import javax.inject.Inject;
    import java.io.DataInputStream;
    import java.io.DataOutputStream;
    import java.io.IOException;
    import java.io.InputStream;
    import java.io.OutputStream;
    import java.net.ServerSocket;
    import java.net.Socket;
    import java.util.concurrent.TimeUnit;
    import com.kuka.roboticsAPI.applicationModel.tasks.CycleBehavior;
    import com.kuka.roboticsAPI.applicationModel.tasks.RoboticsAPICyclicBackgroundTask;
     * Implementation of a cyclic background task.
     * <p>
     * It provides the {@link RoboticsAPICyclicBackgroundTask#runCyclic} method
     * which will be called cyclically with the specified period.<br>
     * Cycle period and initial delay can be set by calling
     * {@link RoboticsAPICyclicBackgroundTask#initializeCyclic} method in the
     * {@link RoboticsAPIBackgroundTask#initialize()} method of the inheriting
     * class.<br>
     * The cyclic background task can be terminated via
     * {@link RoboticsAPICyclicBackgroundTask#getCyclicFuture()#cancel()} method or
     * stopping of the task.
     * @see UseRoboticsAPIContext
    public class TCPServer extends RoboticsAPICyclicBackgroundTask {
        @Inject
          Socket Server;
          byte[] RXRawData = new byte[1024];
          private static String RXString = new String();
          ServerSocket serversocket;
            String delims = "[<>]+";
            String tcpconnection = "CLOSED";
            private static boolean ServerConnected = false;
            private static boolean MessageReceived = false;
            private static boolean ApplicationClosed = false;
            private static String Test;
            @Inject
        @Override
        public void initialize() {
            try {
                serversocket = new ServerSocket(30001);
                Server = serversocket.accept();
                } catch (IOException e) {
                    e.printStackTrace();
            initializeCyclic(0, 500, TimeUnit.MILLISECONDS,
                    CycleBehavior.BestEffort);
        @Override
        public void runCyclic() {
            // your task execution starts here
            try
                if(ApplicationClosed == true)
                if(Server.isClosed())
                    serversocket.close();
                    Server = serversocket.accept(); //Block Function, waits till it finds a client\
                    ServerConnected = true;
                else
                InputStream input = Server.getInputStream();
                DataInputStream in = new DataInputStream(input);
                in.read(RXRawData);
                MessageReceived = true;
                String RXRawString = new String(RXRawData);
                RXString = RXRawString.trim();
                //ServerTransfer_("What happend??");
                ServerTransfer_("/<MSGRCD><Test1><Test2><Test3><Test4><Test5><Test6>");
                String[] tokens = RXString.split(delims,0);
                if(tcpconnection.matches(tokens[1]) /*|| SignalTower.getApplicationState()*/)
                    ServerSocketClose_();
                    ApplicationClosed = true;
                try {Thread.sleep(100);} catch (InterruptedException e) {e.printStackTrace();}
                } catch(IOException e) {
                try
                    } catch (IOException e1) {
                        // TODO Auto-generated catch block
                        e1.printStackTrace();
        //Will call this function in Robot Code when we want to send a message to the PC
        public boolean ServerTransfer_(String message)
          OutputStream output;
        try {
            output = Server.getOutputStream();
            DataOutputStream out = new DataOutputStream(output);
            out.writeBytes(message);
            message = null;
            } catch (IOException e3) {
            e3.printStackTrace();
            //Test = e.getMessage();
        return true;
        public static String getRXString()
            return RXString;
        public static boolean getRobotConnected()
            return ServerConnected;
        public static boolean getMessageReceived()
            return MessageReceived;
        public static boolean getApplicationClosed()
            return ApplicationClosed;
        //Will call this function when PC sends message wanting to close connection
        public void ServerSocketClose_()
          try {
            Server.close();
    This is my first time writing TCPIP. So I probably havent written it in the most ideal way either. But like I said Im trying to close the serverSocket before it is synchronised. I am not too familar with how a cyclic background task comes to an end or if there is a procedure/function I need to write that is called before it is abruptly closed.
  • panic mode
    1,278
    13,079
    • December 9, 2020 at 6:19 PM
    why not make robot a client? then you don't have this issue (and some others)
  • Seulki
    8
    84
    • December 10, 2020 at 5:21 AM
    You could try override dispose() method in your backgroundTask.
        @Override
        public void dispose() {
            super.dispose();    // not so sure this is needed. just my habit.
    And this dispose() method will be called when you press the stop button of the backgroundTask on HMI.
    - you could do it by manually pressing this stop button, or other way to directly call dispose() when you need. ("END" packet from a client or so)
    However, You still need to stop-call dispose()- it before synchronizing.
    I experienced a bug-ish reaction when I try synchronize project without manually stopping a background task.
    It seems the instance is not properly disposed if it the dispose() method hasn't been explicitly called.
