Hello guys,
Can I replace a '' CIB version 1.0.2 '' card with a 1.0.1 version?
And can I replace a '' PMB version 1.0.1 '' card with a 1.0.2 version?
Does this cause a problem? It will work?
KuKa KRC4
KSS 8.2.25
KR 16
Hello guys,
KuKa KRC4
KSS 8.2.25
KR 16
It should work. Usually as long as the KUKA part number is the same, you can exchange the components. Possible issue you get is that the firmware on the older components has a (firmware) bug causing unwanted issues. I've had a problem on a bunch of controllers and only a firmware update solved the issue. And as soon as you change a component, you may install one with a different firmware.
