  4. ABB Robot Forum
DSQC 652 IRC5 Compact Controller
  • devilstang
  • December 8, 2020 at 6:14 PM
  • devilstang
    29
    I need to hook up some I/O to the DSQC 652 unit that is installed into our IRC5 Compact controller. I have been looking at the wiring diagrams and I can't figure out what I'm doing wrong. It looks like the DSQC 652 gets it's power from the XS10 connector internally, but I'm not sure. I turned on output 1 and checked to see if I had any voltage to XS10 but I didn't. Can anyone point me in the right direction? I've been searching google for the past couple days and can't make heads or tails.
  • Moises
    5
    55
    • December 9, 2020 at 10:34 AM
    I recommend you first look for in the forums and 2 step
    take a look at that pdf.
    Files
    d75cbf78635abd9fc481625fc75a92.pdf 667.07 kB – 145 Downloads
    Edited once, last by Moises (December 9, 2020 at 11:03 AM).
  • devilstang
    29
    • December 9, 2020 at 2:37 PM
    I've searched the forums and I have downloaded that pdf. My question was for specific to the IRC5 compact controller. I think I have it figured out. the XS10 connector pin 1 & 2 has 24v and 0v. Pins 3,4 and 5 connect to the X2 and X3 connectors on the DSQC 652 inside the controller. I have to supply voltage to the X2 and X3 connectors for the I/O to work. I'm going to use an external power supply but I guess you could jumper pins 1 & 2 over to power the board if you were letting the robot handle all of the I/O.
  • Moises
    5
    55
    • December 10, 2020 at 3:49 PM
    Please read here:
    https://forums.robotstudio.com/discussion/5001/using-of-dsqc-652
  • devilstang
    29
    • December 14, 2020 at 7:44 PM
    I have wired 24vdc to the XS10 connector on the front of my IRC5 compact controller and my digital outputs are working correctly. I have also wired 0vdc to pin 5 of the XS10 which I think should connect to pin 9 of the X3 connector on the DSQC 652 inside the controller. I cannot get the inputs to work. Does anyone have any suggestions. I have read all of the post and the manuals and I cannot figure this one out.
  • Lemster68
    301
    2,485
    Blog Articles
    7
    • December 14, 2020 at 9:22 PM
    Are the inputs being turned on by an external source with its own voltage?
  • devilstang
    29
    • December 14, 2020 at 10:01 PM
    Yes, they are coming from an external source. I got it working somehow. I opened the case and reseated the X3 & X4 and now they are working. Thanks for the responses.
Similar Threads
  • PickMaster3 in connection with external sensor problem
    • blizz1993
    • July 17, 2019 at 2:21 PM
    • ABB Robot Forum
  • IRC5 Compact - DeviceNet Problems... XS17 Wiring Diagram
    • Nox
    • June 29, 2019 at 12:56 PM
    • ABB Robot Forum
