Deactivating ESM??
  • Im working on an application with Kuka sunrise 1.16.
    I have a few ESM functions that I activate in one of my applications. I got an error from that application so I tried to jog my Kuka iiwa 7 r800 back to its start position. However, it wouldnt allow me to as the ESM was still triggering - even after deselecting the application. I then go to try and run a different application - that doesnt consist of any ESMs to be activated however it is still triggering a stop of motion in that application which i believe is due to the ESM currently active.
    Is there a way to deactive an ESM in a new application and is it possible to jog the robot without the ESM not being triggered.
  • when using ESMs, there is always one active -the one you activated last... and it does not matter which program selected ESM. once you use ESM, you need to ensure to correct ESM is selected - in EVERY program... because one that selected ESM may have crashed before restoring another ESM selection and controller does not automatically switch back to previous ESM when program ends
  • Hello,
    A simple way to make a function of "deactivating ESM" is making an ESM which has no extra effect of safety such as "Emergency stop Local".
    It is already set on KUKA-PSM, and by changing the ESM state to this one, it will work like there's no additional AMF. -But you will see two errors when Local E-stop is pressed-.
    Switch to KRF when ESM is violated. You will still be able to jog the robot and once the safety is insured, the mode will be automatically switched to T1.
  • Hello JM212,
    I am currently experiencing the same problem as you but I am new to kuka iiwa. I don't know how to retrieve the information of whether a program is running or not to change EMS.
    Can you share your background task code?
    I will be very grateful.
  • Hello JM,
    I think you can't do it with a one line code from a background task if you're not using Sunrise,StatusController option.
    However you can still make use of other things.
    You could get ITask instance of your Application class.
    --Your backgroundTask
    @Inject
    private ITaskManager taskManager;
    run() {
        ITask robotApp = taskManager.getTask(YourApplicationName.class);
        // use try-catch - You will get TaskNotAvailableException if your Application is not running.
    You could also make use of ProccessData as a Flag to see if your Application is running.
