Roboguide- backup file
  • Weronika
  • December 2, 2020 at 2:29 PM
  • Weronika
    7
    Hello everyone:winking_face:,
    I've tried create a new cel from file backup and there was a message "The file backup requires H590 which is not supported".
    Does anyone know how to solve this problem:thinking_face:? I made a new cell from file backup from other robot and everything was fine.
    Images
      • 171.58 kB
      • 1,920 × 1,080
      • 95
  • Nation
    Typical Robot Error
    556
    1,937
    • December 2, 2020 at 6:40 PM
    I think that is a mechanical arm number. What arm is your backup using?
  • HawkME
    570
    3,270
    • December 2, 2020 at 7:32 PM
    You may need to update Roboguide to a newer version.
  • Weronika
    7
    • December 4, 2020 at 9:57 AM
    I have the newest version of ROBOGUIDE, and robot which was bought from second-hand. I made a backup and can't open it in ROBOGUIDE. The version of the controller is V7.20P/34. In ROBOGUIDE is only V7.20P/46 version of virtual controller. I' ve contacted with local Fanuc, and asked them to send me files, but they don't have my version of virtual robot controller.
    Files
    BACKDATE1.txt 529 Byte – 52 Downloads
  • ing.diazesquivel36
    • December 4, 2020 at 7:44 PM
    Abre el archivo backdate en el editor de texto de tu preferencia y modifica la versión, de 46 a 36, como indicas que tienes, guarda y abre nuevamente.
    Espero te sirva.
    V7.20P / 46 a V7.20P / 36.
    Quote from Google Translate
    Open the backdate file in the text editor of your choice and modify the version, from 46 to 36, as you indicate you have, save and open again.
    I hope it helps you.
    V7.20P / 46 to V7.20P / 36.
  • massula
    205
    8
    1,440
    • December 4, 2020 at 11:38 PM
    Quote from Weronika
    Where this robot came from? I don't know what is option H590, but I didn't find it on my RG as well, so I'm guessing this is some automaker customization.
    If this robot came from an automaker plant, like GM or VW, You will need to get the correct FRVRC for this specific robot.
    I would also take a look on orderfil.dat file, to see if there is any hint there.
    Anyway, You can try the method mentioned by ing.diazesquivel36
    On some situations, it will work.
  • RookieWithRobots
    76
    • December 8, 2020 at 7:08 AM
    If I remember right this H590 option is spot tool+ option. This might be something that you need weld pro instead of handling pro software in your PC.
  • coldsun22
    8
    • December 30, 2020 at 4:01 PM
    I ran into the same error and I was trying to restore the backup in WeldPro. I switched to HandlingPro and I was able to restore it.
  • amstu
    • May 12, 2022 at 10:12 PM
    Quote from RookieWithRobots
    This suggestion works. I had H541 option error. I select weldpro, not handlingpro, and it's good now.
  • Jadhav nakul
    • March 30, 2024 at 12:18 PM
    I am aslo facing same problem "The file backup requires H590 which is not supported". And i have tried to open backup in Handling pro, Weld Pro and even paint pro, having same error .
    My robot isJM-710iC/20L 7 axes, controller version 8.20.
  • ashley
    5
    66
    • October 3, 2024 at 11:48 AM
    • #11
    Hello, I'm reopening this subject,
    I also facing this problem and coudn't find the solution.
    This is quite awkward to me because I think I have the proper and newest roboguide installation (couldn't find any upgrade on fanuc website anyway...) and when I try to create a new robot I have 2 option of the robot software version and the version V9.30 does provide the handling tool H552 which is required to open the cell...
    any advise?
    thanks
    Images
      • 27.98 kB
      • 491 × 211
      • 6
      • 91.86 kB
      • 808 × 327
      • 10
  • pdl
    272
    1,549
    • October 8, 2024 at 3:22 AM
    • #12
    What version of robot controller do you have?
    You may need an older version.
  • ashley
    5
    66
    • October 15, 2024 at 10:01 AM
    • #13
    The robot controler is R-30ib+ . How could I download an older version?
    thanks for the response
  • pdl
    272
    1,549
    • October 15, 2024 at 6:16 PM
    • #14
    What version of software is running on the robot?
    You can check this from MENU > 1 UTILITIES > 2 Hints:
Similar Threads
  • Roboguide virtual robot startup error
    • pdigre
    • October 7, 2020 at 5:13 PM
    • Fanuc Robot Forum
  • Upload Image backup on roboguid
    • Ant.Espo.87
    • November 27, 2020 at 6:11 PM
    • Fanuc Robot Forum
  • Can't find button to create backup file.
    • vanquang17
    • November 21, 2020 at 11:52 PM
    • Fanuc Robot Forum
  • Updating RoboGuide cell with real-world robot backup
    • SkyeFire
    • July 22, 2020 at 4:41 PM
    • Fanuc Robot Forum
  • Password not working weld pro
    • sanjay bisht
    • August 13, 2019 at 3:52 PM
    • Fanuc Robot Forum
  • Roboguide workcell from backup error
    • AlanL
    • July 9, 2018 at 3:37 PM
    • Fanuc Robot Forum
  • Best way to get tp files out of roboguide?
    • kevilay
    • June 25, 2018 at 1:32 PM
    • Fanuc Robot Forum
  • ROBOGUIDE issue with Robot Serialization from backup
    • Famous_Fella
    • April 26, 2018 at 1:48 PM
    • Fanuc Robot Forum
  • backup file
  • H590
Users Viewing This Thread
  • 1 Guest
