MotoSimEG-VRC
  • This is what my file looks like
    NEWSIMULATOR
    DISPLAY
    DRIVER=OpenGL;
    AXIS_TRIAD=1;
    PERSPECTIVE=1;
    3D=0;
    3D_DEPTH=1.000;
    BACKGROUND_COLOR
    TOP_COLOR=RGB(128,255,255);
    BOTTOM_COLOR=RGB(255,255,255);
    FRAME_LENGTH
    FRAME_LENGTH=100;
    FRAME_COLOR=RGB(0,0,0);
    AXIS6FRONT=1;
    USER_FRAME_COLOR=RGB(128,255,255);
    FRAME_RGB=0;
    USER_FRAME_RGB=0;
    SHADOW
    SHOW=0;
    COLOR=RGB(0,0,0);
    RESOLUTION=192;
    BLURRING=4;
    SMOOTH_TRANSITION
    EXECUTE=1;
    DURATION=1.200;
    LEVEL_OF_DETAIL
    EFFECTIVE=0;
    MARK_UP
    COLOR=RGB(255,0,0);
    LINE_STYLE=3;
    TEXT
    FONT_NAME=sans_serif;
    SIZE=24;
    BACK_COLOR=RGB(128,128,128);
    ROBOT_LIMIT_AXIS
    EXECUTE_INTEACH=1;
    EXECUTE_INPLAY=0;
    LIMIT_VALUE=95.000;
    LIMIT_VALUE2=97.000;
    REVERSE_COLOR=0;
    LIMIT_COLOR=RGB(255,128,0);
    LIMIT_COLOR2=RGB(0,0,0);
    SIMTIME
    SHOW_STATUSBAR=0;
    MULTI_ROBODLG
    EFFECTIVE=1;
    WARNING=1;
    LANGUAGE
    LANGUAGE=ENGLISH;
    UNIT_SETTINGS
    POSITION=mm;
    LENGTH=mm;
    ANGLE=deg;
    WEIGHT=kg;
    PERFORMANCE
    STATICMODEL=0;
    LMV=0;
    DISPLAYLIST=Geometry;
    CULLINGTHRESHOLD=1;
    CULLINGPIXELS=10;
    USEFRAMERETE=0;
    FRAMERETEMODE=Fixed;
    MODEL_LIBRARY
    LIBPATH=C:\Users\Public\Documents\Motoman\MotoSimEG-VRC\ModelLibrary;
    IGES_IMPORT
    HEALING=0;
    RECREATE_SURFACE=1;
    ERROR_ROLLBACK=1;
    SHOW_DIALOG=1;
    IMPORT_HSF=1;
    IMPORT_SAT=0;
    IMPORT_SAFE=1;
    GRAPHICAL=0;
    CAD_EXPORT
    UNIT_NO=0;
    SAT_VERSION=6;
    SHOW_DIALOG=1;
    PICK_SETTINGS
    PICK_OBJECTS=65535;
    PICK_OPTIONS=65;
    MOVE_MODE=8;
    IO_SETTINGS
    DISPLAY_IONAME=0;
    LINE_SIZE
    PEN_WIDTH=1;
    MOUSE_OPERATE
    SCROLL_ZOOM=RBUTTON;
    ROTATE=RBUTTON+MBUTTON;
    PAN=MBUTTON;
    FREE_ZOOM=RBUTTON+CONTROL;
    SHOW_POPUP_MENU=1;
    HIGE_GUIDE_LINE_SETTING
    SHOW=0;
    COLOR=255;
    HIGE_SETTING
    LENGTH=50.000000;
    STYLE=3;
    SHOWPOSNO=0;
    SHOWPOSNO_COLOR=0;
    COLOR=0;
    DIRECTION=0;
    CMOS_BACKUP
    ENABLE=1;
    NUM=10;
    CELLSPATH
    CELLSPATH=C:\Users\Public\Documents\Motoman\MotoSimEG-VRC\Cells;
    CADTREE_VISIBLEINPUTAREA
    VISIBLE=1;
  • It is not being able to read that file and write to that location check in properties and make sure Read and Write have check marks.
