Hi.
The robots was operating normally, but alarm 1322 came up the next day?
Hi.
If this error is intermittent you need to check and see if it is occurring at the same position in your program. This error can happen for various reasons. On the XRC platform I will always clean and blow out the servo pack and regen resistor. Clean dry air only with power off. Check to see if all cables are seated on servo board. The SV 3 robots can be a real pain. I have all the parts you need for repair Autobotics.
the alarm appears one second after the drives are turned on
Do you have any external axis or just a stand alone. If a stand alone this could be a WACR board issue. What version of software are you running ? The WACR has software on it.
I have three robots with positioner. UP6.
alarm is SV1 00000000-00000010
Is this a TRC system running off 1 pendant like a 6300 system. If so I need to know what converter you have in the 1st controller? Converter or Servo board issue .
You can shut system down swap converter 1 with2 and see if problem moves to 2nd converter.
ok I try. thanks.
I can't change WRCA because are diffrent
This is a WRCA with error.
If converter same swap them
The second picture has the daughterboard on it for the external axes. That board can be removed and put on the other. If you are going to swap parts to troubleshoot R2's WRCA board should be the same as R3's.
I swapped converter and the error is not change. On the transformer from the photo I have 255 votls it's too much?
When I change the WRCA board and external I got a error 1304
Did you move the daughter board that was on the WRCA board also? Make sure those cable are on the correct board connectors and are seated properly.
Should I change the board marked in red?
on a three-phase transformer I have 240V, 235V, 229V primary voltage
The board marked in red is an over speed board that is for safety. The board on the right is a auxiliary axis board that takes the feedback from external aux motors. If you are changing boards between servo amps the top boards have to be on new servo board. The daughter boards can cause this error. I usually move daughter boards to different WRCA board and reinstall. You need to remember the system is configured a certain way and software is looking for that hardware in those spots.
This system runs on 20
