I am looking for a valid mada file for the VKR 200 - L120-1A robot. Please share. thank you
VKR 200 L-120 - 1A MADA
- Skowron
- Thread is Unresolved
MADA for what KSS/VSS?
Both kss and vss
You have to provide the exact version number.
for what EXACT version? each is different...
do you expect someone to sift through hundred of MADA for each KSS/VSS and compile MADA collection of some specific robot just because you asked?
and did you check backups or D: on your controller?
Wcześniejsze
Wcześniejsze
Sorry for inaccurate question.
Are these photos enough?
no.... that is nameplate of the robot arm.
it tells nothing about controller, type of software it runs (KSS/VSS) and which version....
MADA for KSS 2.2.6 will not work on VSS 4.1.7 or the other way around
please check READ FIRST...
it shows how to determine software version
Thanks for the instruction. is really helpful.
I was able to determine the version but I'm not sure if it is the original disk from this robot ...
I peeled off the sticker on the nameplate of the robot and there is also a surprise ... I don't know what to think about it ...
