KAREL and Setting up socket server
  • Hi all,
    Do I need to buy the KAREL license option to setup a socket server on the R30iA Mate Controller.
    Or is there a way to do it without purchasing KAREL license?
    I want to send the robot position via TCP/IP to the client side (PC). R648 (User Socket Msg) is installed on the controller.
  • What generation of controller? R30iA and up you will need a license for Karel.
    You will likely need Karel to send the robot's current position out via TCP/IP.
    If refresh rate isn't critical, you could just query the robot's webpage every second or so.
  • Thank you for your reply Nation.
    FANUC Robot LR 200 iC/5L and R30iA controller, so I will purchase KAREL.
    The webpage data is too slow for me. Do you know how fast I can retreive the data with a socket server via TCP/IP?
