Step Mode Control
  • jcapotosto
  • November 6, 2020 at 4:00 AM
  • jcapotosto
    7
    Hello all, I am looking for information regarding controlling Step Mode. I have a robot (R30ib -HandlingTool 7.7) that will not enter step mode while in automatic cycle. When the teach pendant is enabled it will allow step mode.
    I have compared all of the step settings to other identical robots and they are the same. Any ideas? I have gone through the system variables and step mode settings I could find in the manual.
    I am starting to think there is a Karel program blocking it.
  • Famous_Fella
    25
    131
    • November 6, 2020 at 10:01 AM
    I can't think of a reason why to put a production robot actually producing, in step mode during auto instead of just pressing hold :smiling_face_with_sunglasses: but this is propably the variable you need to check: $RSMPRG_SV.$no_step.
    When in AUTO mode check the status of this variable. Check any KAREL routines or BG LOGIC that mess around with this variable.
    Also check $SSR STRUCTURE and specificaly $SSR.$singlestep.
  • jcapotosto
    7
    • November 7, 2020 at 12:43 AM
    Quote from ps0f0r
    Those are the variables I compared to the other robots and they are identical. I personally don't use the step function in that manner, but the people on the floor do when they want to stop the robot right before a point they want to touch up.
  • lajko9
    • March 30, 2021 at 2:40 PM
    Hi
    is this problem solved? I need same thing.
  • neighbour1
    44
    405
    • March 31, 2021 at 10:04 AM
    I have no idea whether it was solved or not, but at least some of us uses search engine from the forum :smiling_face:
    I'd presonally check in Prog Select -> Production checks -> Single step. Look at the attached screens.
    Hope this helps.
    Images
      • 15.17 kB
      • 636 × 398
      • 10
      • 11.7 kB
      • 636 × 398
      • 7
  • Mr_Lletro
    • August 3, 2023 at 5:16 PM
    If the problem is that step mode is forced to disable in auto, you may need to set the system variable $EXT_DI_STEP.$ENABLE = FALSE
Similar Threads
  • Fanuc not running STEP status is in yellow normally in green color
    • Kamran Ahmed
    • April 23, 2019 at 8:01 AM
    • Fanuc Robot Forum
  • Controlling state of DO FANUC R-30iB
    • fmiroslav
    • October 13, 2020 at 10:20 AM
    • Fanuc Robot Forum
  • Step Mode and Multiple Control (RUN 'Program') -
    • jbabineaux
    • January 24, 2020 at 6:19 PM
    • Fanuc Robot Forum
  • KRC4 remote control via PLC. Step-by-step.
    • vivanov
    • August 24, 2017 at 6:00 PM
    • KUKA Robot Forum
  • Reversing through a program in AUTO mode - error recovery
    • paul892
    • March 21, 2019 at 11:17 AM
    • Fanuc Robot Forum
  • STEP MODE w/ R30 ib Plus Controller
    • jrv5207
    • July 21, 2018 at 9:45 PM
    • Fanuc Robot Forum
  • R-30iB Mate: set UFRAME and stepping from a PC without add. software option
    • AlexanderJ
    • August 1, 2017 at 7:23 PM
    • Fanuc Robot Forum
