Programming robot on PC
  • PetrBroza
  • November 5, 2020 at 1:39 PM
  • PetrBroza
    49
    • November 10, 2020 at 5:44 PM
    • #21
    Back to the original topic.
    How do I edit *.TP program? If I open it Roboguide, I can only edit it on virtual pendant, it's just like editing program on real pendat, plus I have to import/export to real robot.
    If I export it to *.LS file, I'm editing just plain text, have to write everything manually and do import/convert/export.
    Is there other program which can make programing easier?
    I have quite a few positions/movements so I need to switch them around, rename PR registers, split them into programs, then create similar programs for second robot, which is quite time consuming on the pendant.
  • Nation
    Typical Robot Error
    542
    1,924
    • November 10, 2020 at 5:46 PM
    • #22
    You won't be able to access the robot's webserver from the profinet card. You have to run a short jumper ethernet cord from the card to a controller port. Also make sure the controller port and the profinet port have unique ip addresses, otherwise a conflict will occur.
  • HawkME
    568
    3,268
    • November 10, 2020 at 7:33 PM
    • #23
    There is no dedicated IDE to make text based programming better. If you want to program in text, your best option is to find a nice text editor that has a syntax highlighting plugin/file for Fanuc TP programs.
  • PetrBroza
    49
    • November 11, 2020 at 7:54 AM
    • #24
    Oh wow, that's pretty expensive option just for text editor. I found plugin for notepad++, if anyone is interested (windsortech dot eu / download).
    How about PR/DIO? I didn't found a way to export them from *.VR/*.IO to *.LS to be readable for the text editor.
  • TomTom
    49
    • November 11, 2020 at 9:49 AM
    • #25
    *.VA are the readable counterparts to the *.VR files. There's also a lot of *.DG files on the robot that contain some readable stuff. I recommend using the HTTP Server that comes with most newer robots. In RoboGuide that's accessible under the "Robot" dropdown menu and then under "Internet Explorer". Alternatively you could also connect with any FTP tool to localhost while RoboGuide is running. There are lots of files that you don't normally see.
    The PR are in POSREG.VA for example. For DIO it depends if you mean the IO configuration or the current IO signals.
  • HawkME
    568
    3,268
    • November 11, 2020 at 3:44 PM
    • #26
    The Register and IO files cannot be compiled from text, but you can view them in text. For Registers and IO you can use the web server Comment tool as TomTom stated.
  • PetrBroza
    49
    • November 12, 2020 at 10:52 AM
    • #27
    Thanks gents. So if I would like to shift positions in PR around, I would have to manually reteach them or manually punch in positions coordinates, correct?
  • hermann
    407
    2,612
    • November 12, 2020 at 11:49 AM
    • #28
    Yes, or you can do it in a program.
  • PetrBroza
    49
    • November 12, 2020 at 12:18 PM
    • #29
    What do you mean by "do it in a program"?
  • hermann
    407
    2,612
    • November 12, 2020 at 12:30 PM
    • #30
    You wirte a program where the PR[] will be manipulated.
    PR[1,2]=PR[1,2]+100
    Shifts the Y coordinate of PR[1] for 100mm.
  • PetrBroza
    49
    • December 10, 2020 at 1:04 PM
    • #31
    Is there way to convert posreg.VA back to posreg.VR? I've tried to import it into OlpcPro, but it does not recognize VA file
  • HawkME
    568
    3,268
    • December 10, 2020 at 1:26 PM
    • #32
    No, I said in my last post you cannot do that.
    You can copy them wholesale from one robot to another. You can assign values to them programmatically. You can modify descriptions on the webserver. BUT you cannot import the .va text file, it is for your reading enjoyment only.
    I think this would be a good one to add the the Fanuc wish list.
  • PetrBroza
    49
    • December 10, 2020 at 1:38 PM
    • #33
    That's ridiculous, given that there is just 100 PR. Thanks for answer tho
  • TomFoolious
    130
    • December 10, 2020 at 1:50 PM
    • Best Answer
    • #34
    Quote from PetrBroza
    You can expand the number of PR's if you have enough memory via Controlled Start -> Menu -> Program Setup -> Position Registers. I've had to do this in the past for a home routine that needed to retain multiple points in two jobs to bring the multi-arm controller's robots home from any taught position. I was able to go up to 285 on that setup before the controller kept wiping out any number above that number. So primitive brain Tom said "OK that's the max I can do with the memory I have". Not sure if I'm completely correct and safe to think that way, but I haven't heard anything from that customer that the home routine isn't working.
Similar Threads
  • KAREL programming FANUC
    • Kawazaki02
    • September 29, 2020 at 5:18 PM
    • Fanuc Robot Forum
  • Fanuc Roboguide Grinding
    • pasu979
    • April 30, 2020 at 9:22 AM
    • Fanuc Robot Forum
  • KUKA Programming tools
    • loopindex
    • November 3, 2020 at 9:47 PM
    • KUKA Robot Forum
  • Bizarre GET_REG behavior
    • SkyeFire
    • October 26, 2020 at 7:12 PM
    • Fanuc Robot Forum
  • VKRC4 offsets
    • Roboter321
    • November 2, 2020 at 12:36 PM
    • KUKA Robot Forum
  • one doubt about a KUKA instruction.
    • danao
    • October 23, 2020 at 4:25 PM
    • KUKA Robot Forum
  • Calibration of tool using irVision
    • RudiVoller
    • October 21, 2020 at 5:09 PM
    • Fanuc Robot Forum
  • CPC programming
    • BubbaSr77
    • September 29, 2020 at 11:07 PM
    • Fanuc Robot Forum
  • Programming Styles
    • Im not a robot
    • May 30, 2019 at 9:00 PM
    • Fanuc Robot Forum
  • HELP WITH FANUC R2000ib 165 F
    • Fran94
    • February 10, 2017 at 8:39 PM
    • Fanuc Robot Forum
