pause and resume
  • Robotmei
  • October 13, 2020 at 1:54 PM
  • Robotmei
    203
    hello,
    KSS V4.1.5
    are there any variables in KUKA with the exact functions of "STOP" and "START FORWARD" buttons on the pendants? I want to hold and resume the programs with two push buttons anytime within the programs running.
    thanks for any help
  • panic mode
    1,268
    13,040
    • October 13, 2020 at 1:57 PM
  • Robotmei
    203
    • October 13, 2020 at 3:05 PM
    I want to use these two signals remotely not with KCP. on HMI or on my own operator panel
    Fubini
    272
    1,873
    • October 13, 2020 at 3:15 PM
    And how do you hope to handle SPOC? All you can do is use the specified automatic external interface.
    If you do not need to deselect the interpreter you might be able to stop the robot by setting $OV_PRO to zero using a signal and then restart by restoring its value.
    Fubini
  • MOM
    175
    7
    1,419
    • October 13, 2020 at 3:28 PM
    SPOC is only important while running in T1 or T2
    On AUT and EXT this is not an issue
    Reason:
    In T1 and T2 the safety gate may be open and any external action could cause someone gets killed (that is why SPOC)
    In AUT and EXT the safety gate has to be closed (and nobody in) and therefore you only can destroy your tool, part or robot - no personal harm(!?)
    Your boss does not like you anymore if you destroy a prototype part (costs app. 1,000,000.00 $) - at least my former boss would not like me anymore)
    Just think about:
    what are the problems you may run into?
    what are the advantages of doing it in the way you want to do it?
  • panic mode
    1,268
    13,040
    • October 13, 2020 at 3:38 PM
    Quote from Robotmey
    the answers can be only as good as question asked, you mentioned two buttons and they are available :winking_face:
    if you want to use external signals to pause and resume program you need to be a bit more specific... like what operating mode... and if you have a PLC there... or at least several I/Os.
    for example you could use two inputs to set/reset $OV_PRO... or you could do pretty much anything with EXT mode.
  • Robotmei
    203
    • October 14, 2020 at 4:36 PM
    I have connected robot to PLC so I want pause and resume robot program in automatic external mode. I can't use $OV_PRO because i have at least 10 programs with different values of $OV_PRO.
    I used $MOVE_ENABLE signal to pause robot motion but it doesn't act like STOP botton on the pendant.
  • panic mode
    1,268
    13,040
    • October 14, 2020 at 4:52 PM
    oh my... i have seen such cases, not fun... in fact i cringe when $OV_PRO is repurposed like that.
    robot program should run fine (just at different speeds) with ANY value of $OV_PRO. only then $OV_PRO can be used as intended.
    in the SPS loop add something like (assuming input 43 is used to request stop)
    IF ($MODE_OP==#EX) AND $PRO_ACT AND $IN[43] THEN
       Stop_Robot_Program()
    ENDIF
    and here is what the STOP_ROBOT_PROGRAM.SRC should look like:
    DEF Stop_Robot_Program( )
      DECL STATE_T s
      DECL MODUS_T m
      CWRITE($CMD,s,m,"STOP 1")
      Wait sec 0.1
    END
  • Robotmei
    203
    • October 17, 2020 at 7:49 AM
    you mean I must send stop and resume commands by serial channel ?
  • hermann
    405
    2,596
    • October 17, 2020 at 8:24 AM
    Nope, if you look closer to the code you will see that the action is triggered by the input nr. 43.
    This cwrite ($cmd.... is an internal communication channel, where the robot interpreter can communicate to the system kernel.
  • DannyDJ
    62
    495
    • October 17, 2020 at 12:44 PM
    • #11
    You could also do it with interrupts if you just want to stop and resume the movement of the robot... For example if signal is FALSE the robot stops, if TRUE the robot continues with the program and movement...
  • Robotmei
    203
    • October 18, 2020 at 11:16 AM
    • #12
    As @panic_mode said i wrote a program in SPS.sub and with $CMD command robot stops with an digital input. It acts exactly like STOP botton on the pendant.
    But RUN in CWRITE Line doesn't act like "START FORWARD" botton on the pendant.
    I am looking for appropriate resume signal.
  • panic mode
    1,268
    13,040
    • October 18, 2020 at 4:54 PM
    • #13
    You don't want CWRITE for start... That is used to select and and run program from begin when no program is selected.
    But you have have program selected and particularly executed, you just need to continue....
    Which is what external start is for. Just pulse it
  • Robotmei
    203
    • October 21, 2020 at 11:52 AM
    • #14
    Thank you for your help @panic_mode, now in #EXT mode I can pause and resume program.
    Is there Program start signal (like $EXT_START) in #AUT mode for program resume ?
  • hermann
    405
    2,596
    • October 21, 2020 at 12:29 PM
    • #15
    No. That's what mode ext is used for.
  • SkyeFire
    1,044
    9,391
    • October 21, 2020 at 4:30 PM
    • #16
    Quote from Robotmey
    No. AUT is built on the assumption that you have no external I/O to use for the $EXT_START, $DRIVES_ON, $CONF_MESS, etc, signals. So for AUT mode, it is required to perform all these functions using the teach pendant. AUT mode actually ignores all the Auto-Extern signals, even if you have them configured.
    EXT mode is the opposite -- it ignores any teach pendant actions, and only pays attention to the external signals.
  • Robotmei
    203
    • October 21, 2020 at 7:01 PM
    • #17
    Well, it is reasonable, thank you
Similar Threads
  • BRAKE, RESUME, continues path and RESUME point
    • saeid ss
    • August 20, 2020 at 11:36 AM
    • KUKA Robot Forum
  • UR Pause and Play
    • moelsayed
    • September 30, 2020 at 5:15 PM
    • Universal Robots
  • Pausing a program with an input
    • Orange_Will
    • August 2, 2020 at 6:46 PM
    • KUKA Robot Forum
  • KUKA INTERRUPTS
    • rush22
    • May 7, 2019 at 11:59 AM
    • KUKA Robot Forum
  • How to Stop in phase a Fanuc Robot
    • VagosT
    • February 7, 2020 at 7:22 PM
    • Fanuc Robot Forum
  • Fanuc Interrupt
    • Robotmei
    • June 5, 2019 at 9:00 AM
    • Fanuc Robot Forum
  • Pause milling from remote control upgrade
    • Marco
    • April 14, 2017 at 12:44 PM
    • KUKA Robot Forum
