does anyone have experience with kawasaki KLadder?
KLADDER
Jj Collewijn -
October 12, 2020 at 10:19 PM -
I am working on a robot that has to work on scratch. when I make a timer. after the time, I control output Y17. then IN16 goes high.
is this normal or is there an incorrect parameter. you would say if you make Y17 high then make O16 or O17 high. -
Any chance you can reduce your font size, it comes across as being a little abrupt?
What do you mean by 'work on scratch'?
What Robot controller are using?
What are you intending to do and what hardware are you using?
What do you mean by Y17?
What do you mean by IN16?
Have you checked and operating using the correct addresses located in Section 2.3 of the KLadder Manual.
Can you provide a copy of your LSQPG file?
