Hi! this is my first job with Moulding Machine and Robot.There are two signals, mould area free and enable mould closure, to interlock the moulding machine. Are worspace definition useful to manage those two signals or at least the area free? I've seen some program that use triggers on kuka program to manage these signals. Before the robot start to enter into the machine they turn OFF area free and when the robot is outside tey turn the signal back ON. The enable colure is usually OFF since the robot is ended the operation and it is outside then the signal is turned on and only when the moulding machine has completed it's closure and is opened again this signal is reset.
It is not more coherent use worspace definition for the signal area free? Since an operator could move the robot in a wrong position and the signal area free could stay TRUE...
