Math with XYZWPR variables in Karel?
  • Darkbound
  • October 11, 2020 at 7:11 PM
  • Darkbound
    65
    Hey guys, I am having some trouble doing math with XYZWPR variables.
    I have two XYZWPR variables, say pos1 and pos2.
    At first I tried to subtract them and get the result into a 3rd XYZWPR variable like so:
    VAR
    pos1, pos2, pos3: XYZWPR
    BEGIN
    pos3 = pos2 - pos1
    END
    But I got an error saying:
    Operator expected POSITION data type for left operand.
    Any idea how to properly do math with that datatype?
  • hermann
    407
    2,615
    • October 12, 2020 at 12:10 AM
    VAR
    pos1, pos2,pos3 : XYZWPR
    pos4: POSITION
    BEGIN
     pos4 = pos2 : INV(pos1)
     pos3 = pos4
    END
    The robot in most times does automatic conversions between XYZWPR and POSITION.
  • mahboobelahi93
    82
    • November 5, 2021 at 9:35 AM
    Quote from hermann
    VAR
    pos4: POSITION
    BEGIN
     pos3 = pos4
    END
    Is it possible to access fields of POSITION data just like XYZWPR?
    I have initialized
    uframe, utool : POSITION
    and gett the following error.
    What is the correct syntax to access fields of this position variable? This works for an XYZWPR
  • TitusLepic
    112
    7
    442
    • November 5, 2021 at 4:13 PM
    POSITION.LOCATION.X
  • mahboobelahi93
    82
    • November 8, 2021 at 8:11 AM
    Quote from TitusLepic
    POSITION.LOCATION.X
    Thanks TitusLepic
  • mahboobelahi93
    82
    • November 8, 2021 at 8:44 AM
    POSITION.LOCATION.X
    Just to confirm,
    Does the orient field contain the roll, pitch, and yaw values? and Location field just contains XYZ values?
  • mahboobelahi93
    82
    • November 8, 2021 at 8:46 AM
    I am having the following error now
  • TitusLepic
    112
    7
    442
    • November 8, 2021 at 4:32 PM
    Quote from mahboobelahi93
    Just to confirm,
    No. This is a matrix representation of the point. The location vector just contains XYZ values, but if you're looking for WPR representation you'll need to convert your position into XYZWPREXT. I believe that karel automatically converts between the data types, so you should be able to declare a new variable as XYZWPREXT and then assign it your position value. Something like this:
    uframe : position
    uframe2 : XYZWPREXT
    uframe2 = uframe
    write(uframe2.x,cr)
    I haven't tested this but from what I've read it should work.
  • mahboobelahi93
    82
    • November 8, 2021 at 9:12 PM
    Thanks, I did similar but i use INV() built-in.
