Increase limit of joint 6
  • Vlad222
  • October 2, 2020 at 12:53 PM
  • Vlad222
    161
    Hi all,
    I have MA1440 DX200. It has limit of T-axis (joint 6) +/-210 degrees. I want to increase it to +/- 350 deg. Am I right that T-axis physically has endless rotation?
    I can't do it from Software limits or using Maintenance Mode. I also tried to change PARAMETER->S1CxG 405 and 413 fields but after that I had PULSE MECHANICAL LIMIT.
    How can I do it?
  • ljuba
    33
    5
    281
    • October 2, 2020 at 4:29 PM
    Vlad, the endless rotation is an FD parameter. You need to contact local yaskawa representative for it.
    You are right about endless rotation on axis 6.
  • 95devils
    235
    8
    1,951
    • October 2, 2020 at 4:32 PM
    Yes, you are correct that the T-axis can go endless. Yaskawa has to turn on the parameter for that. There are mechanical and motor limits also. Call Yaskawa and have them adjust the limits to get you +- 350 or 360.
Similar Threads
  • FANUC PROJECT: Data recording with background Karel program
    • Axillus
    • August 12, 2019 at 5:56 PM
    • Fanuc Robot Forum
  • CR-35iA Collaborative J1 Force feedback issue
    • MRoalsvig
    • January 7, 2020 at 10:55 PM
    • Fanuc Robot Forum
  • Challenger ArcMate question
    • guilherme.simoes
    • December 6, 2017 at 12:57 PM
    • Fanuc Robot Forum
  • 6th axis Upper and lower joint bond
    • Mr.Robot
    • October 10, 2019 at 1:52 PM
    • ABB Robot Forum
  • FANUC SERVO PARAMETER
    • AUTOMANITION
    • October 18, 2018 at 2:17 PM
    • Fanuc Robot Forum
  • Robot path for PTP motion between same coordinates is different.
    • arash
    • May 22, 2018 at 7:46 PM
    • KUKA Robot Forum
  • Collision Guard Specifications
    • Tico
    • December 21, 2017 at 12:03 PM
    • Fanuc Robot Forum
  • Movement stops
    • Plc_User
    • January 25, 2017 at 9:42 PM
    • Fanuc Robot Forum
  • Need to slow down 7th Axis
    • Tim
    • December 31, 2016 at 3:25 PM
    • Fanuc Robot Forum
