newbie to fanuc robot
  • javaman
  • September 25, 2020 at 9:05 PM
  • javaman
    5
    318
    Hello.
    I have already kuka robot and know the basics for kuka krc2 robots.
    I got a fanuc R-30iA robot and i don't know how to start with fanuc...
    What software i will need for using the robot for milling applications ?
    What manuals must read to start with fanuc robot ?
    Iam totaly newbie and need some guidance how to start...
    (i have knowledge about cnc machines and i know the basics for kuka robots)
    Thank you.
  • Go to Best Answer
  • HawkME
    570
    3,270
    • September 25, 2020 at 11:02 PM
    What robot model? What software?
    What are you milling?
    Most likely you want to purchase the HandlingTool manual. If you're milling simple shapes you can program them directly in the teach pendant. If you are doing crazy 3d sculptures then you probably want to purchase cam software.
  • javaman
    5
    318
    • September 25, 2020 at 11:40 PM
    M-900iA
    What cad-cam ? fanuc robot runs g code ?
    Is there a startup tutorial for the basics of fanuc robots ?
  • Skooter
    173
    2,077
    • September 26, 2020 at 1:47 AM
    This is a very broad question. Taking it all in might work out better with more specific questions. Your Kuka expertise will help you once you learn the similarities.
    Following HawkME's suggestion, >HERE< is a manual at a very reasonable cost on eBay. It would be a tremendous help.
  • javaman
    5
    318
    • September 26, 2020 at 3:21 PM
    This manual ships only to US and all items > 22eur outside europe stop at customs and need clearance.
    Can i find this manual in electronic form ?
  • HawkME
    570
    3,270
    • September 26, 2020 at 6:38 PM
    Buy it from your closest local Fanuc rep.
  • hermann
    412
    2,629
    • September 26, 2020 at 6:57 PM
    You can search the internet for "fanuc educational cell exercises pdf" and "fanuc educational cell pdf" and you will find two documents that can already help a bit. Depending in your other skills.
  • Roboticien12
    15
    • September 27, 2020 at 1:09 AM
    Hello JA,
    You can ask Fanuc for Roboguide software, it will help you to understand fanuc robots and for programming also.
  • javaman
    5
    318
    • September 27, 2020 at 10:42 AM
    OK i found a lot of manuals on scribd.
    Also i have roboguide.
    One question fanuc R-30iA can interpret 5 axis milling G code except from karel ?
    If no is there a plugin that can read G code ?
    M-900iA/L260 how it compares with a kuka kr240 in mechanical characteristics ?
    Which has better mechanics ?
  • javaman
    5
    318
    • October 10, 2020 at 8:53 AM
    I received the robot with control R-30iA but the power mains plug cable is cut.
    The plug that was on robot has 6 terminals+ground and the old cable (4 wires+ground wire) was connected to 1/2/3/4 terminals (5/6 was unconnected).
    The 3 phases are 1/2/3 and neutral is 4 ?
    Edited once, last by javaman (October 10, 2020 at 9:03 AM).
  • javaman
    5
    318
    • October 10, 2020 at 6:48 PM
    • #11
    my control R-30iA does not have mode switch selector is always in auto mode.
    How can i add mode selection switch?
    I mean how is the wiring?
    Also how can i disable completelly profinet safety? Because i have SRVO-419 alarm
    Images
      • 2.19 MB
      • 3,000 × 4,000
      • 1
  • Skooter
    173
    2,077
    • October 12, 2020 at 8:26 PM
    • #12
    There is a software option that converts NC codes to Teach Pendant Program (TPP). Not sure of the details.
    R-30iA 3-pos Mode Switch with wiring is Fanuc # A05B-2500-C071, without wiring is A55L-0001-0253#B.
  • javaman
    5
    318
    • October 13, 2020 at 9:14 PM
    • #13
    Can i use a generic 3 position switch?
    How to wire it?
  • Skooter
    173
    2,077
    • October 13, 2020 at 11:43 PM
    • #14
    Logic
  • Skooter
    173
    2,077
    • October 13, 2020 at 11:45 PM
    • Best Answer
    • #15
    Connector CRT9
Similar Threads
  • Software Request to Fanuc - the robot forum bugs and wish list
    • Werner Hampel
    • August 17, 2019 at 11:12 AM
    • Fanuc Robot Forum
  • Paint pro simulation software
    • wag_FFU
    • July 27, 2020 at 1:45 PM
    • Fanuc Robot Forum
  • Fanuc Robot got issue with INTP-202 alarm
    • Lambu
    • February 12, 2020 at 1:37 PM
    • Fanuc Robot Forum
  • Controller battery problem
    • padin33
    • May 30, 2018 at 11:20 AM
    • Fanuc Robot Forum
  • How to transfer data from PC to FANUC Robot.
    • nhochamcuoi
    • January 16, 2018 at 12:28 PM
    • Fanuc Robot Forum
  • I’m a newbie and need help with setting up a program
    • KFirebaugh
    • January 3, 2018 at 4:04 AM
    • Fanuc Robot Forum
  • Newbie teach pendant questions with my LRmate200i
    • cityjack
    • October 29, 2017 at 11:22 PM
    • Fanuc Robot Forum
  • Fanuc R-2000ib Pendant
    • GAF1953
    • August 15, 2016 at 1:50 AM
    • Fanuc Robot Forum
  • Fanuc M-10iA BLZAR 065 Error
    • fermat7
    • February 15, 2017 at 8:17 PM
    • Fanuc Robot Forum
  • Robot won't run program continuously
    • cmarin
    • September 30, 2016 at 4:15 PM
    • Fanuc Robot Forum
