On interbus card you could switch from 2MBd to 500 kBd
Meanwhile, just as general info, if you want,
can you explain please how to switch the card between 500 kbsp and 2 Mbps?
Thank you
Thank you
On Master you have dip switches:
DIP Switch 1 thru DIP Switch 3 you select the Card Number
DIP Switch 7
OFF: 500 kbsp
ON: 2Mbps
Interesting, thanks
I'll test another I/O module with the correct speed
Here the result: It was my fault, speed mismatch, now the 2MBD block has arriverd and it works!
