Hello, is it possible somehow to connect one KRC4 SmartPAD to multiple controllers(you select to which one the Smart Pad connects) in the cell from one place... For example, if i have 30 controllers of the same KSS type 8.6 installed on high ground, and i would like to be able to establish connection with only one KRC4 SmartPad to desired controller from one central location so that i can drive the robot connected to that controller from that central location.... and without physically going to controller and reswitching the cable from SmartPad to different controllers...
Also buying 30 extention cables and route them to one central place is also not option...
With RoboTeam far as i know it is only possible to 4 robots with one SmartPad...
I also know the Virtual Pendant application... but that is also not suitable because you have to first have controller in EXT in order to move the robot...
I'm thinking of somekind of SmartPad router maybe, i have never seen this, every time for each of the controller there was SmartPad along the controller...
Is this even possible?
