  4. ABB Robot Forum
Error 50080 position not compatible S4C IRB6400
  • 33brad66
  • September 22, 2020 at 6:16 PM
  • 33brad66
    30
    Hi All,
    I've seen threads describing a similar problem, but none that really solve my problem. I'd really appreciate any suggestions.
    I have a robot which throws this error frequently (50080 position not compatible), throughout the workspace, when jogging and in auto run. The mastering is correct, but the world frame is rotated about the Y axis. Base frame is straight.
    I could see the two being connected, but it doesn't seem like the occurrence of the the error matches a path that leads outside of a quadrant, and definitely not to a different configuration. In fact I can jog the robot into a "tunnel" in linear, rotate A6 in reorient, and be completely unable to jog further, until I switch to axis jog.
    CONFL helps in programs, but it's still unworkable while programming positions.
    Bradley Cooper, <br />Robotics Technician<br />Remtech Systems
  • Lemster68
    296
    2,460
    Blog Articles
    7
    • September 22, 2020 at 7:00 PM
    Why is the world frame rotated in such a manner? Is the wrist maybe directly over the center of axis one? (singularity, but not the more common 4,5,6).
  • 33brad66
    30
    • September 22, 2020 at 7:08 PM
    Hi Lemster. I don't know why the world frame would be rotated about Y, but I haven't changed it. The robot is a typical 6 axis for welding. No weird physical configuration.
  • Lemster68
    296
    2,460
    Blog Articles
    7
    • September 22, 2020 at 7:15 PM
    Spot welding? If you are using ConfL\Off then maybe you are near an axis limit. Check the degrees of rotation of the axes when you get that fault, see if you are going to the limit.
  • 33brad66
    30
    • September 23, 2020 at 6:23 AM
    No, it's PTA, and the error occurs EVERYWHERE, with no joint angles near limits. It's very difficult to program, as there are so many unusable positions. There is a clunky joint, A5.
  • Skooter
    167
    2,005
    • September 23, 2020 at 1:31 PM
    Did the TCP change? Can you load in an old backup before this happened and have it work?
  • 33brad66
    30
    • September 24, 2020 at 12:58 AM
    Thanks Skooter. The TCP was good, but I redid it to be sure. I loaded the oldest backup I could find, but apparently this has been a problem as long as anyone still working there can remember. One poor guy has been programming around it for a long time.
  • Skooter
    167
    2,005
    • September 24, 2020 at 4:53 AM
    If the TCP is good and it has good straight line linear motion, that should rule out a wrong wrist installed or wrong robot parameters. I would check System Info in the Service window and verify the robot type matches the physical robot anyways.
    Are work objects being used?
  • 33brad66
    30
    • September 24, 2020 at 6:24 AM
    The robot type, IRB6400, is from a data plate on the controller, there's nothing on the robot. I'll check the system info, thanks
  • Lemster68
    296
    2,460
    Blog Articles
    7
    • September 24, 2020 at 5:50 PM
    Quote from 33brad66
    The joint being clunky would not cause this error, maybe some other errors in the future, but not this one.
  • 33brad66
    30
    • September 25, 2020 at 5:20 AM
    • #11
    I'll check the System Info, as soon as I can. Yes, there is a work object. I'll report back when I have some results, thank you so much.
  • ABB position not compatible
