Hello all
I'm using Roboguide and facing a problem.
I can't turn on button Servo On in auto mode. Every time I tried to turn it on, a error system 34 or 40 happened
May anyone help me, please.
Hello all
Not sure what button you are talking about, can you post a screenshot?
When I click the run button to start the simulation, I can't turn the servo button (the big red circle) from off to on.
So the cursor jump from line to line, but the robot still doesn't move.
That is the teach pendant enable switch. It must be Off to run on auto.
When I click the run button to start the simulation, I can't turn the servo from off to on.
If it is that, I still stuck in finding the reason why my robot doesn't move.
Did you select the program. Go to the select menu and press enter on the program you want to run first. If that doesn't work then check the settings in the run configuration menu in roboguide.
