Hello all,
I never worked with a KAWASAKI robot.
A good customer called me a few minutes ago asking for help. He has bought four J10 robots in the second hand market. 3 of those robots work properly, the last one, can be moved manually (jogging) but it doesn't start the program in automatic mode.
In the pendant/console, he can see a switch EXT.HOLD active which is not present in the other 3 robots.
In one manual I've found in the Internet for the D SERIES CONTROLLER, it states that the signal AUX 0601 should be resetted to be able to perform a start if the ext.hold is not needed.
Having the customer at 300km, being completely impossible to remotely connect to the robot and without having touched one KAWASAKI in my life... could anyone here send me a manual for that controller that explain how to solve the EXT.HOLD problem?
Any ideas what else to check?
Thank you very much in advance.
