Collision Detect Error without even colliding or touching the part
  • sanjay bisht
  • September 9, 2020 at 10:29 AM
  • sanjay bisht
    85
    Guys - I sometimes get collision detect error on my Fanuc robot
    I always check the joint values after getting this to make sure all joint are within my axis limits
    And they always are, none of my joints are at extreme or close to extreme
    My weld wire is also not touching anything , its far away from the clamp or part or surface
    My collision sensitivity is 60%
    Is there anyother reason for this ????
  • Fabian Munoz
    133
    Articles
    1,517
    • September 9, 2020 at 12:35 PM
    Payload ?
    Retired but still helping
  • retobor
    18
    207
    • September 9, 2020 at 2:18 PM
    I have received collision alarms & OVC on welding robots in hot environments; flux-core welding 450+ amps with hour long cycle times. Changing speed and motion path on large joint moves would solve that issue.
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • September 9, 2020 at 2:59 PM
    Quote from Fabian Munoz
    Payload ?
    I agree that is worth investigating. Also, you have it set to be more sensitive than default.
  • sanjay bisht
    85
    • September 9, 2020 at 4:37 PM
    How to look into payload setting? or check if its correct?
  • TitusLepic
    112
    7
    442
    • September 9, 2020 at 4:54 PM
    Menu > Next > System > Motion
  • T1D_Robot
    • September 24, 2020 at 8:46 PM
    If that did not fix it try putting new grease into the joint. Worse case scenario you might have to replace the motor.
  • sanjay bisht
    85
    • September 25, 2020 at 8:37 AM
    I just bought this robot - 6 month back, it should not be the physical issue i guess. Some setting for sure
  • R47
    110
    • September 25, 2020 at 11:26 AM
    hi sanjay, how many robots are Welding on the same Jig?
  • sanjay bisht
    85
    • September 25, 2020 at 12:24 PM
    One robot only
  • R47
    110
    • September 25, 2020 at 2:04 PM
    • #11
    did you checked if there is a air bubble in the transmision?
    how much current is the engine pulling when you are getting this Alarm?
    I had the same behavior few weeks ago.. in my case it was the Engine.. after we changed it the Problem disappeared.
  • moln4r
    128
    • September 25, 2020 at 2:10 PM
    • #12
    You can also check the disturbance in menu > next > status > axis. You have to see DISTURB above the F4 button if I remember right.
  • mbull
    43
    • September 26, 2020 at 2:46 AM
    • #13
    Another thing worth considering is if you have a linear move that is close to your last taught point, but with joint angles that have the robot in a different posture. The robot may try moving fast enough to error out on an axis speed limit, and if it's already moving fast enough the sudden stop may trigger a collision alarm. What is the specific error you are getting, and how does it appear? What I mean is are you getting a yellow warning like this one, or just an alarm in the message window and fault history?
