How do I create an XML file for read/write protect to change certain system variables?
Sep 2nd 2020 #1 How do I create an XML file for read/write protect to change certain system variables?
Sep 3rd 2020 #2 Are you trying to prevent variables from being changed, or are you wanting to change them?
Sep 4th 2020 #3 If you have the J541 Password Protection option you can use something as shown below to prevent certain users from accessing or modifying system variables. Change the level #'s and access 0/1's to meet your needs.<SCREEN level="1" sp_id="34" scrn_id="1" access="1" rw_access="0"/><SCREEN level="2" sp_id="34" scrn_id="1" access="1" rw_access="1"/><SCREEN level="3" sp_id="34" scrn_id="1" access="1" rw_access="0"/>Without J541, you may be able to set the specific system variable in BG logic - depending on the user this may not be effective either.
