i got a program backup from UR and I used URSIM-UR10 to read the program which I have in back i got the below message.
so how can i get this installation file or which back-up do I need to get it from UR.
Thanks In Advance
Moelsayed
Thanks In Advance
Moelsayed
When You make a backup on a UR, You normally have the program (.urp file) and the installation file (.installation file), and also a .txt program version, and also a .script file.
Installation file has all the information about the robot setup. If You have access to the robot, try to make a new backup. If not, ask the people who sent You the program to send also the installation file (it is normally called default.installation).
Please note that, if the robot use some option, like a URCap, you will also need this installed on the simulator, or You will end with unrecognized instructions.
Thanks Massula for this information.
when I checked the back files I found Installation file and when I load it if found the configuration for I/O it is still different according to what I have in TP.
as I understand the installation should contain the I/O configuration is it correct ?.
How can I get the correct I/O configuration please.
also I noticed when I am doing backup the for [ program ,configuration,Log file ) the I am getting two times green USB word in TP but I am not getting the last third green USB so I removed USB after 5 min without getting the third green USB word.
I don't know for who long should I wait till the process to be done.
and I found the backup files has two different project name ( one for the current project and it has Main program which is currently running now but without Installation file , and another project file has Urp file + Installation file "when I am loading it to URSIMI found the I/O assignment became different according to what I have on TP ).
what is that I don't know.
Thanks,
Moelsayed
The problem solved what I have done I just repeated again the the same process for back up the program and I waited approximately 8-min then I got the green USB and I removed USB then I found the instillation file loaded with program file.
Thanks,
Moelsayed
