I Have a KUKA KR 120 palletizing robot.
I want to make the robot move along the Z axis of a stack with pallets and record, with a sensor the positions of the pallets. But i cant see a way to do soo. I have tried different ways of looping the movment soo the robot only goes 2 millimeters before checking and repeating the motion. But both loops and WHILE Loops excecutes an advance stop, the function works, its just too slow and looks bad. Any one with any leads on what i'm doing wrong or an better idea, of how to make this possible?
Measuring positions while moving robot
Brende -
August 29, 2020 at 4:25 PM -
HawkME
August 29, 2020 at 6:42 PM Moved the thread from forum General Discussion of Industrial Robots Only to forum KUKA Robot Forum. -
Why not using interrupt and save the position of the pallets with $pos_int?
interrupt is a way to go
Quote
advance run point is a very important concept. this is why for anyone working with robots, one of the first things one should learn is what advance run pointer is, how it works, how to use it, what are the risks, when and how to control it.
both advance run and interrupts are discussed many times, just use search function.
Thank you soo mutch, i looked into the older threads as you said. I found one your exsamples on measuring. it was a real eye opener. thank you soo mutch for the help.
